84 trunk pop vs 91 pull down.
Old Jan 9, 2007 | 10:39 AM
luvofjah's Avatar
Car: 91 Black Formula KR
Engine: 305 TPI R69/G92
I had an 84 TA with trunk pop... worked great... I want it back..
My 91 Formula has a trunk pull down...
My question, can I use the 84 system and totally replace my 91 stuff?
Are the mounting points and stuff the same?
Raf
Old Jan 9, 2007 | 05:00 PM
2kflhr's Avatar
Car: '68 396 SS/RS, '02 SS
I'm not sure if the '84 will work in the '91. Lon at www.topdownsolutions.com can answer this and probably will once he see's this post.
My son has a '91 that didn't have the console hatch release switch. I bought the release solenoid from Lon at TDS and installed it. I decided to not install the console switch at this time but it can be released from his alarm remote aux. button.
Old Jan 10, 2007 | 08:51 PM
HCR13's Avatar
Car: 1987 Trans Am
Engine: 355ci L98 soon to be turbo'd
Axle/Gears: 2.73 posi
I actually just finished a similar mod a couple of weeks ago, but insead, what I did is beefed it up with two electric motors (thank you junkyards) and replaced the shitty nylon guides with a pair of wheel-bearing sets (typically used for patio sliding doors) and I heavily bolted the motor housings to the mounting braket... works like a charm, no more rattle over bumps...
Old Jan 11, 2007 | 05:52 PM
MNformula350's Avatar
My Formula had the power pull down, and I replaced it with a regular slam hatch assembly from an 84 Camaro.
I had to drill out the factory spot welds on the bracket for the pull down (And on the donar cars bracket), then I rivited the new bracket in place to get it all aligned, and then a buddy of mine welded the bracket for the new assembly in place, and now I have a regular slam hatch type assemlby like the 82-85 cars did from the factory.
777Shock777
Oct 29, 2015 04:30 PM
gta power
Convertibles
Sep 23, 2015 09:32 AM
AmorgetRS
Convertibles
Aug 31, 2015 11:55 AM
86IROC112
Aug 31, 2015 07:00 AM
stalkier
Aug 21, 2015 01:54 AM
