Gauge cluster swap?
Old Jan 11, 2007 | 01:39 AM
MARO-MAN's Avatar
Car: I've had 4 thrid gens!!
Engine: Someday again I will have another!!
Gauge cluster swap?
Does a newer/later(90-92) third gen gauge cluster swap right in place of the older third gen clusters? Here is a picture of the cluster I am talking about. Thanks, Nick.
http://cgi.ebay.com/ebaymotors/82-92...QQcmdZViewItem
Old Jan 11, 2007 | 02:34 AM
bluethunder28's Avatar
No. They are totally different.
Old Jan 11, 2007 | 05:58 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
blue is correct. Not only is the 90-92 version designed differently but it's also electronic. You'll need the mechanical version, 82-89. The 82-84 speedo heads have the dual pointer, so personally I'd stay away from them. The 85-89 speedo heads come with 85, 110, and 140. Take your choice. Unless you have dummy lights, these are direct swaps, plug and play.
JamesC
Old Jan 11, 2007 | 02:12 PM
MARO-MAN's Avatar
I don't need a new cluster, my 145mph Iroc cluster is fine. I was just curious and couldn't find anything with the search button. Thanks much. -Nick.
Old Feb 15, 2008 | 09:50 PM
GTAwheelman's Avatar
Car: 1985 Sport Coupe
Axle/Gears: 3.08
Re: Gauge cluster swap?
JamesC
what do you have to change if you had dummy lights? i bought a 85 Camaro that had the dummy light gauge, then the owner before me swapped it out for 140 cluster. the temp gauge and oil pressure gauge no longer work.
he said to replace the sending units all will be fine. is this true?
Old Feb 16, 2008 | 01:28 AM
mcgarnicle's Avatar
Car: 1991 Z28 1LE
More than likely, of course no way to tell without taking a look at it.
Old Feb 16, 2008 | 05:32 AM
JamesC's Avatar
what do you have to change if you had dummy lights? i bought a 85 Camaro that had the dummy light gauge, then the owner before me swapped it out for 140 cluster. the temp gauge and oil pressure gauge no longer work. he said to replace the sending units all will be fine. is this true?
Welcome to TGO. Probably replacing the sending units will do the tricks as mc mentions. Check the following link for more info (a search on this site is always a good choice):
https://www.thirdgen.org/gauges
JamesC
Frozer!!!
Jan 19, 2024 04:55 PM
Jeremys87
Jul 14, 2022 09:08 PM
fonzie85
Aug 13, 2015 11:50 AM
ChevyZ71
Aug 13, 2015 07:30 AM
