HVAC issue...
Car: 1987 F150...PAAARTY FOUL!
Engine: 300 I6 stump pullin sumbiscuit
Transmission: 4 speed grind box
Axle/Gears: 3.55 unlimited slip differential
HVAC issue...
i have an issue with the project car i just picked up, looking for answers...the blower motor only works on the 3rd fan setting...barely. that's not a big deal, new blower motor. but the issue is this, even in the "Vent" setting, no air comes through, at all. what would this be, a vac issue, unhooked duct work, something else i'm missing? or does the blower motor just restrict the air from coming through? every other F-Body i've had if you put it in "Vent" mode, the air will just freely blow through...but not this one
Josh
Josh
Car: 91 rs,1 92 rs,92 b4c/1le
Engine: 5.0tbi,5.7 tune port/5.0tpi
Transmission: 5spdx2 and t56
Axle/Gears: 3.08,3.73,3.42
check to see if the heater box is full of leaves or the heater core is plugged
well, the heater core is currently bypassed (previous owner, i just got it) so it could be plugged...
Josh
Josh
Bohemian
Aftermarket Product Review
Nov 25, 2015 09:38 PM
777Shock777
Oct 29, 2015 04:30 PM
Chevykid810
Sep 28, 2015 12:57 PM
