Interior Neons (Dome Light Tapping)
Old Jan 17, 2007 | 06:54 PM
Rocketerz's Avatar
Car: 1990 RS Camaro
Engine: V6
Transmission: Automatic
I had a question, wondering if anyone knows. I was looking to tap into my dome lights to have neons come on when the dome does, I noticed next to the actual bulb theres a screw coming out of the light, Is this giving off a power source to tap into, Anyone know? Thanks so much
Matt
Old Jan 18, 2007 | 12:24 PM
Stealthy-One's Avatar
Car: 89 RS
Engine: 2.8
Transmission: 700r4 auto
Axle/Gears: huh?? guessing stock.
Hit it with a DMM and see what it says. Dont now what screw you are talking about, but thats about the best way to find if something is hot or not.
Old Jan 18, 2007 | 12:35 PM
z28onTweenkies's Avatar
Car: 1992 Camaro Z28 & 2k3 Cadillac CTS
Engine: LB9
Axle/Gears: 3:43
I'm not an expert at this but I have tapped into the door pins before with good results. You might also want to look into the headlight switch as a source of power for your neons. That screw you mentioned in your post is not a hot, it is only a rivet that holds the dome light to the roof, IIRC
Old Jan 18, 2007 | 01:41 PM
Rocketerz's Avatar
Car: 1990 RS Camaro
Engine: V6
Ah ok, thanks so much for the info. Ya ive been lookin all over for the wire to the dome lights, It's been pretty nasty weather here so I havent really spent valuable time lookin. so ill check it out, tysm (:
Matt
Old Jan 19, 2007 | 07:55 PM
Rocketerz's Avatar
Car: 1990 RS Camaro
Engine: V6
I had a question, I was lookin today and I think I found the wires to dome light. I found a plug-in double wire running to the dome light, It was whitish grey. Does anyone know if this is it? Im hooking up neons, Will they run off this switch? Should I hook a fuse in between? Thanks so much
Old Jan 19, 2007 | 09:03 PM
Jtufts's Avatar
Car: 1989 camaro rs
Engine: 305 TBI
Transmission: 700r
i am gonna tap into my defroster power , casue my defrosters dont work but it is getting power
Old Jan 19, 2007 | 09:54 PM
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
neons, neons??? Have I slipped into an alternate forum where that's cool???
Old Jan 21, 2007 | 02:21 PM
JeremyNYR's Avatar
Car: 1984 Trans Am
Axle/Gears: 10 bolt w/ 4.10 gears
that screw you are referring to holds the dome light assembly into the roof. No power supply there. There is a 12v power source that runs up the drivers a-pillar, over to the center above the visors, and to the domelight. The door switch is on the ground (negative) side of the dome light circuit. I'd suggest starting a new 12v power supply from the fuse box for your new lights and run your negative wire through the door switches (behind your kick panel) so they turn on and off with the doors if that's what you want. You'll probably want the option of switching them on with the doors closed too though. you can run a branch off the negative side that goes to a switch before a ground. It's much easier to see than read. I'll try to draw it up quickly:
thinking about it some more, I wonder if you'd be best off to just run the neons off of a manual switch. I believe they run off a ballast that may not like being turned on and off frequently.
Old Jan 21, 2007 | 07:09 PM
Rocketerz's Avatar
Car: 1990 RS Camaro
Engine: V6
Thanks so much for your info. Yes I am planning on running this to a switch. I was thinking, I think I found the wire under the dash to the left running to the dome light, It's a white wire. My idea, tell me if this sounds right or wrong. Ok from the neons I wanted to strip that wire and run the positive wire of the neons to that, Take the negatives, run them to a switch, and then other to a ground. Pretty much exactly what you said So will like any screw in the floor or something work as a ground? so much
Matt
Vintageracer
Jan 10, 2020 05:33 PM
1992CamaroGirl
Dec 25, 2017 08:45 PM
Omega
Aug 10, 2015 12:46 PM
