switch panel
Old Jan 23, 2007 | 07:53 PM
niceroc's Avatar
Car: 87 iroc
Engine: 454 .030 over
Transmission: th-350
Axle/Gears: 9 bolt
switch panel
im pretty sure that im going to get a switch panel for my ign., fans, fuel pump and other stuff on my car to simplify the wiring but i was wondering id any one had an idea of where to mount it, one idea i have was right above the HVAC controls, or maybe replace them if i dont run them, heres a pic of the panel i was htining of getting, its 6-1/4" wide x 2-1/2" high
Old Jan 23, 2007 | 09:36 PM
DillonRager's Avatar
i think your ideas would be the best two places to make it look good
Old Jan 24, 2007 | 08:05 PM
niceroc's Avatar
Car: 87 iroc
Axle/Gears: 9 bolt
yea, i was hoping to get some other suggestions or pics
Old Jan 25, 2007 | 12:23 AM
87TAairlineyard's Avatar
Car: 1987 Pontiac Trans Am
Engine: 305 LB9 Tuned Port Injection
Transmission: 700-R4 Automatic
Axle/Gears: Saginaw 10 bolt 2.73 posi
Could you hide it within the center console? I'm not sure of the measurements there but it seems like it would fit.
Old Jan 25, 2007 | 01:13 AM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
i like putting them where i can reach the fuel and ignition switches in case of problems at the track, unfortunately with my 5 point harness that would be too far of a reach with them being by the hvac, so i mounted them near where the fog light switch would be, since I don't have a factory fog light switch.
Old Jan 25, 2007 | 10:30 AM
niceroc's Avatar
Car: 87 iroc
Axle/Gears: 9 bolt
thats a good thing to consider, i have the fog light switch, but no fog lghts so that is a possiblity, do you have any pics of it?
Old Jan 25, 2007 | 01:17 PM
bigmaciroc's Avatar
id have to say lose the radio and put it there, or buy seprat switches and mount them on the center consol where the window switches are, or should be. could got under the center air vents put againt the virtical part of the dash... theres lots of places...
Ghettobird52
Jul 5, 2024 11:18 PM
GTAman
Mar 15, 2019 11:40 AM
Slush92RS
Sep 2, 2015 08:56 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
Dialed_In
Aug 20, 2015 01:45 PM
