driver side window moves
Old Feb 14, 2007 | 09:41 PM
1987camarosport's Avatar
Car: Camaro
Engine: worked 350
Transmission: automatic
Axle/Gears: 3:73
hey all i have a 91 camaro door on my car power windows, the window moves back and forth in the door inorder to get it to seal i need to press on the window to get it to seal from outside or inside i need to roll the window down and almost guide it in is there anyway to fix the wobbling? and make it tight again?
Old Feb 15, 2007 | 08:36 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
You have to remove the door panel, and look at the workings of the window and regulator. It may be worn plastic bushings in the regulator tracks, the felt adjusters may need adjusting in the top of the door, the tracks may need adjusted - there are many potential problems - you won't know until you take the door panel off. I even found a rivet in mine that was never installed correctly from factory - it held the glass to the support. I had to drill old bad rivet out and replace with a bolt/stopnut.
There is a tech article on windows -
https://www.thirdgen.org/windowadjust
1992 Trans Am
Exterior Parts for Sale
Apr 4, 2016 12:50 PM
pfsteichen
Feb 9, 2016 06:59 PM
Street Lethal
Aug 14, 2015 08:25 PM
timonator
Aug 11, 2015 09:56 PM
wruiz
Aug 11, 2015 02:59 PM
