How do you remove the rear seat
Old Feb 16, 2007 | 07:18 PM
Ricco's Avatar
Car: 2011 Cummins HO
Engine: 350 HSR
Axle/Gears: 3.43
I got the bottoms out no bother but i dont know how to remove the seat backs.. It is a split folding affair... 92 Z28.
Any ideas?
Search yeilded 0 results...
Old Feb 16, 2007 | 07:25 PM
ChillPhatCat's Avatar
Car: '10 Subaru Forester
Engine: 2.5 Boxer
Transmission: 4EAT
Axle/Gears: 4.44
There is one bolt on the outer side of each seat holding the backs on, I'm sure you found those. The middle part of each back is fitted onto a bar sitting across the top of the driveshaft tunnel, you have to slide it off of the bar horizontally to remove each half by carefully angling it so as not to bend the metal fitting inside... or if you don't care about re-using the backs you can just bend the outer edge of the seat forward toward the center console and push it off of the bar... that's what I did because mine were completely shot.
Old Feb 16, 2007 | 09:05 PM
Ricco's Avatar
Engine: 350 HSR
Axle/Gears: 3.43
Aha... no, hadnt found that bolt but i hadnt really looked that much either.. I found it now though.
Thanks,
Richard.
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
MORREALE5
Sep 13, 2015 09:16 PM
3rdgenparts
Aug 8, 2015 07:09 PM
z28addict8490
Aug 7, 2015 08:48 PM
