Aftermarket steering wheel adapter ??????
Alright, anyone with pic, description, instructions or just plain comments from the peanut gallery, please respond.
I've decided to "try" an aftermarket wheel. I'll leave my choice unmentioned to keep this thread topic on the wheel adapter. I've seen a few brands that seem to have a rather large obtrusive looking piece that mounts to the column. Is this correct? Is this what you guys running aftermarket wheels have all had to do?
...the adapter is the hardest part for me to swallow.
CAN"T WE TALK ABOUT THIS??????????
Car: 1987 Trans Am
Engine: 355ci L98 soon to be turbo'd
Axle/Gears: 2.73 posi
I have a Grant steering wheel, the adapter hub is, id say, less than 1/2in, but it comes with a "bell" or "bowl" that covers the hub and makes it flush to the steering column. I've very happy that I did...
Car: 98 Z 28/89 L98 Formula
Engine: ls1/Undecided
Transmission: 4L60e/Undecided
Axle/Gears: 3.23/Dunno?
Thats the same exact one I have. Did you get the horn to work, the person who had the car before me had to rewire it to a seperate button by my knees.
Car: 1987 Trans Am
Yeah, I got it to work, but I had to make my own "button mechanism". I'm not sure how the intentional Grant set up is suppose to work, since it comes with a silver(foil) sticker that doesn't even seem like it conducts electricity. What I did is tape a metal washer to the hub/inside steering wheel (connected to the [+] of the horn) and another washer to the plate that holds the horn button in place (which is "pushed away" by the spring) so when I press the horn button, both the washers touch and comple the current, thus HONK!
Car: 92 camaro RS
Engine: 305tbi
Re: Aftermarket steering wheel adapter ??????
can you use these on cars w airbags ... i dont care about losing the bag but does it mount the same
Car: 1987 Trans Am
yeah, it can be used with airbag cars. And obviously, you do loose the use of the air bag. Just cut the wires that go to the airbag and hide them behind the hub. It might cause the SES light to come on but I'm not 100% sure. But the regular Grant hub will fit GM cars...
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Here's another Grant with a billet sleeve:
https://www.thirdgen.org/forums/atta...-out-bezel.jpg
JamesC
JamesC
Car: 1989 Iroc-z
Transmission: 5 speed
Axle/Gears: Posi
do you need a steering wheel puller to remove the factory steering wheel? (if so which kind) and if I got a grant wheel from jegs, the challanger model pictured, which I did will I need an adapter or any kind? thanks.
JamesC
I have a gt grant in my 88. I would say it is a nice wheel, its cheap, and it looks good. But, the horn thing is a joke. I cant believe they sell garbage like that. I wouldnt have installed it personally, but the PO did. He never got the horn working, and I just plain havent bothered. I dont honk at people, I flip them off.
Car: 1989 Iroc-z
Axle/Gears: Posi
Alright how do yall have this challanger wheel on your camaros when there isnt an adapter listed for 82-92 camaros? or if there is where is it, cuz jegs and grant dont list it. Need help...got my steering wheel today..no mention of need for adapter kit till I open the box.
Re: Aftermarket steering wheel adapter ? HELP PLEASE
Need help removing horn botton from hub adapter. I’ve tried prying it off. Even turning counter/clockwise but can’t figure it out. Has anyone encountered a stuck horn button.
need to replace key ignition
HOLY OLD THREAD! ...started by me! (I'm still here)
.....that's definitely not stock. From what I've seen, it appears to just pop out, but obviously that's not working for you. Is there a set screw around the side or something?
No more screws anywhere. No info anywhere on removing horn button from steering wheel hub adapter. My last hope is to chip away at the button till it breaks of -__-
Car: 91 chevy camaro
Engine: 305/5.0
Transmission: T-55 manual
Axle/Gears: Open case
James C.
Where did you get that adapter and did you had to grind it or the kit came like that?
