gages and cruise control
Old Mar 10, 2007 | 02:19 AM
Gramps's Avatar
Car: 87 Camaro IROC
not sure if this should be in the electronics but i thought more ppl would look in here.
lets say that i have a car with cruise control, and my gage cluster blows and i have to replace the whole cluster (all gages and plastic housing and the wire sheet and the VSS). the cluster that i buy came from a camaro without cruise control...my question is...will my cruise control work or do i have to find a cluster with the CC to make it work?
Gramps
Old Mar 10, 2007 | 05:39 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Originally Posted by Gramps
i have a car with cruise control, the cluster that i buy came from a camaro without cruise control...my question is...will my cruise control work or do i have to find a cluster with the CC to make it work?
I have cruise. I've swapped out the original for a 110, then a 140. I've sold many clusters and never once has a problem of this nature arose. As a consequence, I'd guess, your worry is unnecessary.
JamesC
Old Mar 10, 2007 | 07:46 AM
MurcoRS's Avatar
Car: 1989 Camaro RS
Engine: ZZ4 350
Axle/Gears: BW 9-bolt w/3.73
The cruise control cluster housing has an optical pick-up on the back of it for the speedometer on 82-89 Camaros that must be retained for cruise control operation. Just swap the gauges into your housing, connector sheet if nessesary, and you should have no problems.
Old Mar 10, 2007 | 01:37 PM
Gramps's Avatar
Car: 87 Camaro IROC
see i think thats what happened, i bought a cluster with no cruise control pickup, and my old cluster is gone (my dad threw it away). i think that optical pickup is the VSS. but i dont know if my VSS's are working properly and a new one is 100 buks (im cheap eh?).
so there is no difference in cluster housings? no extra wire on the wiring circuit?
Old Mar 10, 2007 | 02:52 PM
MurcoRS's Avatar
Car: 1989 Camaro RS
Engine: ZZ4 350
Yes, the optical pick-up is the VSS input (it has the optical housing and 2 wires that go to a yellow connector (the buffer) and I cannot remember how they attach to the connector sheet. The housings and gauges are the same, I just don't know if there is a different connector sheet for non-cruise cars, I've only had cars with cruise control. I think I have a spare housing at home, I'll PM when I get home tonight if it has the VSS pick-up and buffer still attached, I may have trashed it.
Old Mar 10, 2007 | 03:12 PM
JamesC's Avatar
This from an 86 diagram:
http://92b4crs.tripod.com/86wiring/dia-pics/34-0.jpg
JamesC
Old Mar 10, 2007 | 09:04 PM
Al Hasse's Avatar
Car: 1992 RS / 1989 RS
Engine: 3.1L MFI / Vortec 383 TBI
Transmission: T5 / LS-T56
Axle/Gears: 3.42 open / 3.73 Eaton posi
There are 3 wires, unless there is a difference between 87 and 89. I have a picture with it installed when I put a jumper wire or two on to repair the mylar circuit board.
Old Mar 10, 2007 | 10:17 PM
Gramps's Avatar
Car: 87 Camaro IROC
Originally Posted by JamesC
linky no worky
PS: instead of posting a pic of a wiring diagram(im assuming thats what it is based on what you describe it to be, i cannot actually access the webpage) of a random cluster with no comparison or any comment as to whether or not there is a difference, perhaps you could give comparisons and contribute like the other fine ppl in this thread are trying to do.
Old Mar 10, 2007 | 10:23 PM
Gramps's Avatar
Car: 87 Camaro IROC
thanks murco, ive bought a few clusters myself in search of a good 240km/h speedo, but i dont have the origional cluster from my car cuz my dad threw it out and the one i got preceding that one makes my fuse blow so i cant use that one either. ive pretty much narrowed it down to this cluster thing.
EDIT: how easy is it to damage that buffer or the VSS? and if i did damage the VSS, would i get a code 24?
Old Mar 11, 2007 | 09:27 AM
1FastZ's Avatar
Car: 86 Iroc Z
Engine: 406
Transmission: 350 Turbo
Axle/Gears: 373
I have one if you need it.
Old Mar 11, 2007 | 04:38 PM
Gramps's Avatar
Car: 87 Camaro IROC
you have what? a cluster or a VSS? i can get a new VSS here, im a little weary about buying used electronics over the net...even in person actually.
Old Mar 12, 2007 | 05:48 AM
JamesC's Avatar
Good luck.
JamesC
Old Mar 12, 2007 | 10:21 PM
MurcoRS's Avatar
Car: 1989 Camaro RS
Engine: ZZ4 350
I trashed the connector sheet, sorry, and I cannot find the pick-up/buffer assembly. These are pretty bullet-proof electronics as my car got hit by lightning 10 years ago and it's survived that along with various other "electrical mishaps" over the years. Getting a used one at a boneyard is cheap and worth a try, I don't know if you would get a code 24 with a missing VSS pick-up / buffer assembly (I would guess you would).
junior419
Apr 7, 2025 11:35 AM
wigmobile
Feb 26, 2025 02:56 PM
DiabloWS6
Southern California Area
Feb 15, 2016 02:08 AM
DiabloWS6
20
Dec 11, 2015 04:12 PM
scottmoyer
Sep 7, 2015 07:06 PM
