Need Window Help Badly
Old Mar 14, 2007 | 05:18 PM
BADMAN's Avatar
Car: 1985 Iroc-Z
Engine: 440LSX
Transmission: l460e
Axle/Gears: 3.55 Wavetrac
I removed door panels, plastic weather guard,lowered window all the way down, and then removed screws to replace outer window sweep. I also had to remove filler panel. Installed new sweep and put everything back together less guard and door panel. Now window is about 1 inch back from filler piece.(see photo) I touched no adjustment bolts on window anywhere. Filler piece is right back where it was according to bolt marks. Any idea whats wrong? In photos you can see old mark where window rode in the filler piece groove,now it's where it is in the photo. Badman
Old Mar 14, 2007 | 05:41 PM
BADMAN's Avatar
Car: 1985 Iroc-Z
Engine: 440LSX
Transmission: l460e
Lesson to be learned. Donot work on the car after working all day elsewhere. I forgot about rubber trim piece that rides on window and mounts to filler piece. So I solved my problem by taking a shower and now going to bed. Badman
Old Mar 15, 2007 | 05:40 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Originally Posted by BADMAN
I solved my problem by taking a shower and going to bed.
I find that that solution solves most problems .
JamesC
Old Mar 23, 2007 | 03:08 PM
l_dis_travlr's Avatar
Car: 90 Formula -- tot resto in progress
Transmission: 700R4 w/ 2500 stall, by Owen @ ARD
Axle/Gears: 3.23 posi disc
Re: Need Window Help Badly
And Long-Island Tea also helps
TheTraut88
Sep 11, 2015 05:16 AM
Stryker412
Sep 7, 2015 09:11 AM
Amillionoh7
Sep 5, 2015 11:44 PM
RyanJB
Sep 2, 2015 01:27 PM
FLAP
Camaros Wanted
Sep 2, 2015 09:22 AM
