dash swaps
Old Mar 25, 2007 | 05:09 PM
transamrob86's Avatar
Car: 1986 Firebird
Engine: 2.8
Axle/Gears: 3.42s
dash swaps
so i read the sticky in the other section but it wasnt clear. im not askin about electronics what i want to know is what kind of physical modification has to be done to put a 4th gen dash in my third gen bird?
Old Mar 25, 2007 | 11:13 PM
obeymybird's Avatar
Car: 92 camaro RS
Engine: LSA
Transmission: Magnum F
Axle/Gears: TNT 8.8 wavetrac 3.31
Re: dash swaps
the dash swap is a piece of cake the only real physical work is cutting of the top dash pad an coming up with some A pillar posts the wiring is what kicked my butt took way longer than i thought.
Old Mar 26, 2007 | 05:41 PM
Car: 1986 Firebird
Engine: 2.8
Axle/Gears: 3.42s
Re: dash swaps
how bad was the wiring and the air ducting and such. thats another concern cuz i plan on using the ac and all that.
Old Mar 26, 2007 | 10:43 PM
Slepewesel's Avatar
Car: 91 Camaro Z28
Engine: 5.0 TPI (LB9)
Transmission: 4L60
Re: dash swaps
Read read read.
Wiring was easy. I put a 95 Bird dash in my 91 Z. I have a factory service manual for my Z, and a friend of mine supplied me with all the wiring diagrams I needed for a 95 Bird. Got em from AllData. Just match up function to function, and you'd be surprised how often the wire colors match. Its just tedious work.
Same goes for the HVAC. My only issue is my A/C and Defroster work great, but when I turn it to Vent, the blower motor shuts off. Havent figured that one out yet ...
And the dash itself is easy to get in also. On both sides you will see (when you get your old dash out) two "brackets" extending down the sides of the car (you'll know em when you see em), those gotta be cut out for the 4th gen dash to fit.
Check out this thread ...
https://www.thirdgen.org/forums/body...iring-4th.html
For the heater box modifications. Again, piece of cake.
Oh ya, check out this page also for some more tips, paying special attention to the A-pillar solution...
http://www.ms-fbodies.com/jade_ta.htm
Jorlain
Aug 24, 2022 05:11 PM
The_Phoenix
Feb 4, 2016 07:10 AM
Pilotrick50
Sep 2, 2015 12:48 PM
TA8487
Interior Parts Wanted
Aug 23, 2015 01:34 PM
Vintageracer
Aug 11, 2015 08:13 PM
