replacing plastic seatbelt shoulder guide
Old Mar 30, 2007 | 11:44 AM
sam356's Avatar
Car: 1992 Z28
Axle/Gears: stock
Do you have to remove the seatbelt stitching to slide these on? I find it hard to believe that they were assembled with the plastics on there from the factory, but can't see how I would get them on.
Thanks,
Sam
Old Mar 31, 2007 | 06:24 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: replacing plastic seatbelt shoulder guide
The ones you speak of, yes, it appears they were installed at factory as belt was being assembled. Easiest thing is to cut them off, trash them, and get replacements like those in the link below - these bolt up diectly in the same holes, and they split apart to install over belt - look close and you can see the split:
Seat Belt Guides
Old Mar 31, 2007 | 09:48 PM
Jay's Avatar
Jay
Car: 88 IROC
Engine: 5.7 RamJet
Axle/Gears: Dana44 4.10
Seat Belt Guides
They all come like that.
Old Mar 31, 2007 | 10:20 PM
TheScaryOne's Avatar
Car: 1987 IROC-Z Camaro
Engine: L98 5.7L TPI
Transmission: 700-R4
Axle/Gears: 3.27 BW
I thought he was referring to the guide at the very top that plugs into the roof. I can't see how that comes apart either, and one of the clips on mine broke.
Old Apr 1, 2007 | 09:37 PM
Jay's Avatar
Jay
Car: 88 IROC
Engine: 5.7 RamJet
the replacements for those that I have seen have a slit for them. One of the vendor sponsors sells them.
Old Apr 3, 2007 | 10:24 AM
Car: 1992 RS
Engine: Carbed 350
Not all - in my 1990 and 92 there is a completely different "loop" on the seat top - it's a double loop, so that a shorter person can pull the belt through the lower loop and get the belt off their neck. These have no slots, they were put on before the final stitch (and they are ugly lol).
The roof guides must have been put on before the final stitch as well - as mentioned the replacements have a slit in them to install - you can also get them from the boneyard and carefully cut a slit yourself to get them off and reinstall them.
Old Apr 3, 2007 | 12:34 PM
Bobby_80s's Avatar
Car: 1987 Camaro, 1986 Trans AM
Engine: V6 2.8 multi-port and V8 5.0 FI
Transmission: 5-Speed and Automatic
Axle/Gears: no idea
go to http://www.moderndaymuscle.com/ they sell those kind of seat belt loops your talking about
Old Apr 3, 2007 | 11:45 PM
Jay's Avatar
Jay
Car: 88 IROC
Engine: 5.7 RamJet
Ah. You're right. I know what you are talking about but had forgotten about them. Aren't the 4th gen ones like that too? I have black seat belts from a 92 Formula but I don't remember what they have for guides, they are sitting in a box somewhere.
Old Apr 8, 2007 | 12:53 PM
krisb410's Avatar
Car: 91 RS Camaro, 75 L82 Corvette
Engine: LO3, 383 Stroker
Transmission: 700R4, TH400
Axle/Gears: 4th gen 3.23 posi/LS1 discs, stock
I cut a slit in the roof plastic piece, nobody notices it, did the same with the 4th gen style guides on the seats.
1992 Trans Am
May 10, 2023 07:19 PM
Jeremys87
Jul 14, 2022 09:08 PM
Fronzizzle
Mar 18, 2019 08:29 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
scottmoyer
Interior Parts Wanted
Aug 9, 2015 10:18 PM
