Insturnment cluster problems
Car: 1989 camaro IROC-Z G92
Engine: GM 355
Transmission: Mad Dog 700R4
Axle/Gears: 3.27 :(
hey, I was wondering if any of you know what I should do. I have a 89 camaro I-ROC and I just put a speedometer cable and gear in the car. the speedometer now works but the other gauges do not. It seems like i installed the insturnment cluster wrong but it all bolted back up. the gauges were working before I put the cable in. could it be the circuit board?, the bulbs still work liek the turning signals and the dash lights just not the rpm gauge oil pressure and engine temp. any advice would be helpful, thanks alot!
Shaun
Shaun
Car: 84 camaro s/c
Engine: 305 slightly tweaked
Transmission: TH400
Axle/Gears: 3.42 single stripe
Re: Insturnment cluster problems
try checking your gauge fuse and the electrical connections on the back of the cluster to make sure they're seated properly
