fuse problem
Old Apr 29, 2007 | 08:23 PM
Z_wonderer's Avatar
Car: 86 z28
Engine: LB9 305 TPI
Axle/Gears: 2.73 gears
fuse problem
hey guys, i just bought my first camaro, it's a white 86 IROC-Z and i have a problem with the acc fuse. i dont know where the problem is but when i try to put in a new fuse it gets blown instantly. now i want to try something but i dont know if it's safe. i want to put a small stip of aluminum foil around a blown fuse.i want to know what you guys think about this. please reply thanx
this is what i'm talking about
Old Apr 29, 2007 | 08:32 PM
88KARRV6's Avatar
Car: All sold :-(
Engine: None
Transmission: None
Axle/Gears: None
Re: fuse problem
you really should not do that, unless you want an electrical fire.
if you are blowing fuses, it is because there is a wire shorting out, acc fuse controls your dome lights and radio and several other systems.
get yourself a book (haynes is fine) and try to hunt down the short, it's the only way to fix your problem.
I seem to remember that autozone.com offers some free wiring diagrams, so you might want to check that out.
Old Apr 29, 2007 | 08:34 PM
hwcoll95's Avatar
Car: 1989 Iroc rebuild
Engine: 355 carb'd
Transmission: 5spd
Axle/Gears: 3:08 pos for a while
Re: fuse problem
i would try and find the short before i heat it up and burn a connector or wire by doing the foil thing,unhook some of things on the acc circuit,does it have and aftermarket stereo ?if so i'd start there
Old Apr 29, 2007 | 08:39 PM
thedude's Avatar
Car: 85 Trans Am
Engine: LG4
Re: fuse problem
Yeah, that's a bad idea to do if the fuse is blowing. If it continually blows, then there's something wrong with the circuit. Removing the fuse will just make whatever problem you have worse and is very unsafe. find out everything that is on that circuit and remove things one by one until it doesn't blow, or trace all wires and look for the problem. A real common reason for blown fuses stems from the cigar lighter, not sure if it's on that circuit or not. Try removing it and see if that helps.
Old Apr 29, 2007 | 09:43 PM
Z_wonderer's Avatar
Car: 86 z28
Engine: LB9 305 TPI
Re: fuse problem
you mean like unpluging it?. so where can i find all the plugs for all these accesorys.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
andy74
Sep 3, 2015 08:41 AM
GeneralIesrussi
Sep 3, 2015 03:23 AM
Jackrabbit501
Sep 2, 2015 09:14 PM
greenyone
Sep 2, 2015 03:39 PM
