In Dash LED's
Old May 3, 2007 | 11:55 PM
TG Goose's Avatar
Car: 1985 Camaro Z28
Engine: 355 SD TPI
Transmission: 5spd w/Hurst Short Throw
Axle/Gears: 4th Gen 3.42 LS1 Brakes
In Dash LED's
just thought I would post some pictures of this. I did this about 9 months ago, but forgot I took pictures when I did it.
use Superbrightleds.com WLED-x6 LED Wedge Base Bulbs in red.
kind of blurry, but you really need a tripod for night pictures.
2 sets of Varad 5 led strip lights under each side of the dash as well.
3 hidden quite well, and 1 not so well hidden one...will have to take some time to make it blend a little better tho..
Old May 4, 2007 | 01:27 AM
killerklown's Avatar
Car: 1990 Firebird
Engine: 3.1
Re: In Dash LED's
Looks cool. Im doing that mod myself (under dash) and hope to have it done by end of weekend w/pix.
Old May 6, 2007 | 10:09 AM
TG Goose's Avatar
Engine: 355 SD TPI
Re: In Dash LED's
the dash lights are so much brighter than stock and I am definitly glad I went red bulbs. Its so nice to finally be able to see the guages at night and the red LEDs are so soft on the eyes.
Old May 6, 2007 | 10:22 AM
cooltc2004's Avatar
Car: 1992 Firebird
Engine: 3.1L V6
Transmission: 5 Speed Manual
Axle/Gears: 3.42 Peg Leg
Re: In Dash LED's
Lookin good, I did that, but I used the x5, which throws out a wider pattern.
Nice!
Old May 6, 2007 | 03:27 PM
Car: 1990 Firebird
Engine: 3.1
Re: In Dash LED's
Just did this yesterday. 5 star led's in reflective marker housings and a red toggle switch. Also have the x6 in the map lights and led fetson dome light, same place you got yours superbrightleds.com all RED!!!
-A tripod would help me as well...
Old May 6, 2007 | 06:04 PM
thedude's Avatar
Car: 85 Trans Am
Engine: LG4
Re: In Dash LED's
I fabbed up the underdash lights in my Trans Am for $5 total, for all materials. I used a set of cheap clearance lights, and it looks great. Just for anyone that wants the look on a smaller budget. If I had a better cam I'd take pics.
Old May 7, 2007 | 02:18 PM
Car: 1990 Firebird
Engine: 3.1
Re: In Dash LED's
Take pix w/your crappy camera cause I want to see
Old May 7, 2007 | 05:24 PM
thedude's Avatar
Car: 85 Trans Am
Engine: LG4
Re: In Dash LED's
I'll try to do it tonight when it gets a little darker here. I'll post a new thread explaining how I did everything. I'll send a PM your way when I get around to taking pictures and making the thread.
Old May 7, 2007 | 05:30 PM
krisb410's Avatar
Car: 91 RS Camaro, 75 L82 Corvette
Engine: LO3, 383 Stroker
Transmission: 700R4, TH400
Axle/Gears: 4th gen 3.23 posi/LS1 discs, stock
Re: In Dash LED's
I used these bulbs from superbrightleds.com too, but in orange/amber.
Looks pretty good, but a tad bit to dark after I added the white faced overlays. But I recomend them if you don't have the overlays.
Old May 7, 2007 | 06:15 PM
Car: 1990 Firebird
Engine: 3.1
Re: In Dash LED's
Cool! We can swap stories then...I love lights
For some reason its hard to get the gauges to light up evenly w/LED's cause there light travels a diff path than standard bulbs. I do know that its all about "reflection", if that can be achieved somehow then the gauges will light up like a volcano!
TG Goose can you post up more pix of where you have your led's mounted? I will do mine later and post some pix for you to see.
Last edited by killerklown; May 7, 2007 at 06:20 PM. Reason: Automerged Doublepost
Old May 7, 2007 | 06:36 PM
2tonedmaro89's Avatar
Car: '91 RS
Engine: 5.0L gross *** tbi
Re: In Dash LED's
i want to do something similar to those gauge lights. can someone explain to me how they were installed
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
Fanatic1074
Oct 2, 2015 03:47 PM
lewandom
Oct 1, 2015 08:15 AM
