roll-up cover mount location?
Do all interior side panels have the hole locations indented for the roll-up cargo cover? The black panels I swapped into my wife's GTA do not have holes. Any help?
Car: '85 Firebird
Engine: 2.8 V6
Transmission: stock BW 5 spd.
Axle/Gears: stock 3.42
Re: roll-up cover mount location?
all the ones I've seen do.
I don't know how to cut them out though, if you figure it out let me know. (I have the same problem)
Axle/Gears: 3.45, 3.27, 3.27
It should have the location lolded on the inside of the trim panel. Are you adding the roll-up shade to a car that didn't have the option? If so, you may want to know that there is a bracket spot welded to the car inside of the trim panel that the shade receiver screws into. I cut it out of a junker and pop-rivited it to mine.
Lon
Lon
Lon
Lon
ambainb
Apr 25, 2016 09:21 PM
IROCZDAVE (88-L98)
Sep 13, 2015 09:07 PM
