Custom-fitting headunit enclosure
Old May 23, 2007 | 08:50 PM
TAshifter88's Avatar
Car: '88 Firebird
Engine: LB8 V6 2.8L
Ok, so I finally went and bought a radio-pod for my firebird. Now that THAT is out of the way, I have to work on getting the actual headunit in the little devil. My only problem is just that, getting the headunit in, as everyone else has probably already experienced. I was wondering if there were any places that sell conversions that will your average sized headunit into an '88 firebird's, or if I'd have to do some molding myself?
Old May 24, 2007 | 08:47 AM
jkicak's Avatar
Car: 87 Formula 350
Re: Custom-fitting headunit enclosure
are you talking about an aftermarket deck?? if you are you will need to go to your local install shop or crutchfield and buy a dashkit for your car.
Old May 24, 2007 | 09:06 AM
GTA_IN_T.O's Avatar
http://fitguide.installationexcellen...tegoryId=1#787
Old May 24, 2007 | 10:37 AM
Car: '88 Firebird
Engine: LB8 V6 2.8L
ya, that's what it is, a dashkit. I don't know if there's a universal size or not, but my aftermarket headunit is roughly 2.25" tall and 7.25" wide.
And I'm looking at the link you posted, GTA_IN_T.O, however I'm not sure exactly which model number has what I want exactly. I have the radio pod and the face plate for the radio/HVAC system, so I just need the dashkit to fit it in easier. I'm looking at the models, but they all look pretty similar, and I don't want to mess up and get the wrong one. Any help on the right one? I'll start looking through crutchfield and the sort. Thanks again everyone.
EDIT: I guess this should do the trick?: http://www.crutchfield.com/S-V8ojBeR...0&I=120903524P
Old May 24, 2007 | 11:11 AM
GTA_IN_T.O's Avatar
that will work......do you not have a local stereo shop near you the should have them in stock
Old May 24, 2007 | 11:31 AM
Aviator857's Avatar
Car: 1989 Firebird
Engine: 5.7 LS1
Most autozones, bestbuys, and even walmart has the adapter for our cars. If you still have your old radio you need to get the brackets off the side of the radio as most GM din and a half mounts on the side so the kit I got I had to take the little angle brackets off my old radio and put on the adapter. My first install I couldn't find a place that had an adapter that was flat, most for some reason extends out 2 inches, which I thought looked dumb. So I went to an office store and got a black plastic clip board. Got out my dremal and made my own plate. Unfortantly that got stolen with the radio when I was in college. But since just about every car GM made in the 80's had the same size radio, the adapters are numerous, some fit better than others.
Old May 24, 2007 | 11:55 AM
Car: '88 Firebird
Engine: LB8 V6 2.8L
hmm, ok. Ya, I'll probably stop by Tweeters or something again. That's where eI got my 2000 F150's, but I wasn't sure if there were still many out there for a car that's 20+ y/o. I'll stop by and see what they have.
Oh, and I don't have the original h/u anymore. The radio pod was actually stolen from it the first time, then the car was sold to me. I just put in my aftermarket h/u from my truck.
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
JannaMan
Car Audio
Nov 4, 2001 08:16 AM
DJSexay
Car Audio
Apr 27, 2001 10:45 AM
PhantomTPI
Car Audio
Apr 23, 2001 09:19 AM
dhirocz
Car Audio
Apr 5, 2001 08:15 AM
