new steering wheel
Old May 28, 2007 | 10:13 AM
resop27's Avatar
Car: 89 325is, 91 z28
Engine: 2.5l 6, l98
Transmission: t56
Axle/Gears: 3:42
new steering wheel
i was wandering if you could putan aftermarket wheel on a 92 camaro i dont like messing with that airbag since the wheels already out and my horn buttons are broken soo i dont know if aftermarket wheels have a horn or not and if they even fit?
Old May 28, 2007 | 10:18 AM
online170's Avatar
Car: 1987 Firebird
Engine: 355
Re: new steering wheel
You CAN put it on. Horns come with after maket wheels, its basically a simple spring loaded switch. You have a wire going to a metal ring usually, and the center of the horn button has a spring pushing up on it. When u push the button, the metal contacts on the horn touch the ring, completing the circuit and the horn goes off.
If you ever work on removing a steering wheel, push the seat ALL the way back, and dont sit directly in front of the wheel. It may kill you. The safest way is to pull the column out and remove it that way. Ive heard its usually a YELLOW wire. Dont mess with it.
83 Crossfire TA
Jan 3, 2016 01:26 PM
SG91camaro
Sep 5, 2015 10:27 PM
WickedBowtie
Exterior Parts Wanted
Sep 5, 2015 04:58 PM
rudolphschenker
Sep 4, 2015 02:41 AM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
