Dash lights to LED
Old May 29, 2007 | 10:37 AM
Spiers's Avatar
Dash lights to LED
I want to replace my dash lights with red L.E.D.'s... now how many are in the gauges first? 9-right? and they are 194-right? Okay also I need to replace the bulbs in the HVAC/climate controls are they 194 also? How many?
I also need to replace the shifter indicator light and what kind of bulb is it? Lastly and most importantly how to I change the fog/defroster/hatch switches light to red to match all the gauges and such?
Old May 29, 2007 | 11:47 AM
I H8 WWD's Avatar
Car: 89' IROC-Z
Engine: LO3
Axle/Gears: 10-Bolt/2.73
Re: Dash lights to LED
Here ya go.
http://www.sylvania.com/ConsumerProd...RG-Results.htm
High & low beam headlamp
H4666
H4666ST Silverstar High Performance Lighting: The Whiter and Brighter Halogen
H4666XV XtraVision Halogen Upgrade: 3x brighter; 2x the life
H4666CB Cool Blue Halogen Upgrade: White Hot; Super Cool; 100% Street Legal
Parking light
2057
2057LL Long Life Upgrade: Up to twice the life of the standard lamp
Front turn signal
2057
Rear turn signal
2057
Tail light
2057
Stop light
2057
High mount stop light
3156
3156LL Long Life Upgrade: Up to twice the life of the standard lamp
Fog/Driving light
H3-55W
H3ST Silverstar High Performance Lighting: The Whiter and Brighter Halogen
License plate
194
194LL Long Life Upgrade: Up to twice the life of the standard lamp
Back up light
1156
1156LL Long Life Upgrade: Up to twice the life of the standard lamp
Front sidemarker
194
Rear sidemarker
194
Ash tray
161
Glove box
194
Map light
194
Dome light
211-2
Step/Courtesy light
194
Trunk/Cargo area
168
Under hood light
93
Instrument-general
161
194
74
Hi-beam indicator
74
Seat belt indicator
74
Brake warning
74
Automatic transmission indicator
161
Directional signal indicator
74
Old May 30, 2007 | 01:10 PM
Spiers's Avatar
Ok thank you, I have already seen that, but that doesn't really answer my question... that lists both 194 and 161 for instrument-general, so what about the HVAC and the fog/defrost/hatch switch?? Also that doesn't list the shifter indicator
Old May 30, 2007 | 08:14 PM
AdmAnt13's Avatar
Car: 1990 Pontiac Firebird
Engine: 3.1 V6 soon to be gone
Transmission: 700r4 Automatic soon to be a T56
Well I did it to my gauges only. 9 bulbs all 194's.
The other stuff I'm not sure. I looked at the one inside the fog light console shining down and had no idea what it was and I've seen my share of light bulbs. I'd like to know as much you do since I have blue cluster lights and orange red HVAC controls and such.
Old May 31, 2007 | 09:20 AM
Spiers's Avatar
Well actually they don't have to be leds... based on pictures I found I would rather go with colored glass bulbs than leds because it looks as if the leds don't light up the gauges evenly. I got into the hvac, shifter, and fog switches and such and the Hvac has three 74 bulbs and the shifter is one 74, and the switches have these really really small bulb behind them I haven't figured that out yet...
Old May 31, 2007 | 09:34 AM
AdmAnt13's Avatar
I did LEDS and it lit up fine. The trick is to get the 5 led wide angle leds. It has one strong LED in the center, and 4 smaller ones projecting in different angles to the side. VERY BRIGHT and have a great color. The whole gauge is lit up with no gaps.
Old May 31, 2007 | 12:47 PM
I H8 WWD's Avatar
Car: 89' IROC-Z
Engine: LO3
How about posting some pictures or video of the light show in day and night...Thanks....cant wait to see them...what color again?
Old Jun 3, 2007 | 09:51 AM
AdmAnt13's Avatar
sorry guys, been away for a few days. I'll post some pictures tonight once it gets dark. Day time pics are worthless, the camera will not even pick up the light in the gauges. Besides, unless you windows are limo tinted, no one turns on their dash lights during the day anyway.
Old Jun 3, 2007 | 09:59 PM
AdmAnt13's Avatar
Here you go. Actually, they about 10% brighter with the engine on, but its late and I don't need to wake the neighbors (loud car).
It doesn't look too bright in the picture, but I assure you they are in real life. My camera kills the brightness.
Old Jun 6, 2007 | 11:25 AM
SK_1983-TA's Avatar
Car: 1983 Firebird Trans Am
Engine: 305, hopefully 350 or 400 soon
Hey AdmAnt13 where did you get the 5 point LED lights? I saw some on ebay but the ones that I saw were coming from Japan. If you could let me know where I would appreciate it, thanks!
Old Jun 6, 2007 | 01:33 PM
krisb410's Avatar
Car: 91 RS Camaro, 75 L82 Corvette
Engine: LO3, 383 Stroker
Transmission: 700R4, TH400
Axle/Gears: 4th gen 3.23 posi/LS1 discs, stock
www.superbrightleds.com has them, that's where I got mine from.
Old Jun 6, 2007 | 03:23 PM
SK_1983-TA's Avatar
Hey Thanks Krisb410!
Do you or anyone else know what the difference is between polarized and non-polarized? Some said that on them, just wondering.
Which ones did you buy, the ones with 5 leds? There are ones with 4 leds and 6 also would those fit too? Or would the ones with 5 be the best because of the way they spread?
Thanks!
Old Jun 6, 2007 | 03:33 PM
AdmAnt13's Avatar
thats where I got mine too. They are awesome. Stick with 5 led one...I know it works.
Old Jun 6, 2007 | 09:48 PM
cooltc2004's Avatar
Car: 1992 Firebird
Engine: 3.1L V6
Transmission: 5 Speed Manual
Axle/Gears: 3.42 Peg Leg
Look pretty even to me
Old Jun 7, 2007 | 07:14 AM
AdmAnt13's Avatar
Looks even better than mine, car was on though right? My camera sucks too.
You know whats cool? I only got 56,000 miles. I baby that car way to much.
Old Jun 7, 2007 | 10:49 AM
SK_1983-TA's Avatar
Hey guys that bought the 5 leds from superbrightleds.com, were those just pop the old ones out and replace with these leds? No wiring or new conectors? Did you have to remove the cluster from dash or just the bezel and plastic lens cover? Let me know, thanks for the input so far.
Old Jun 7, 2007 | 11:31 AM
AdmAnt13's Avatar
The old one just come out and the new put pop in. No soldering, wiring..nothing.
How I did it was I took off the bezel and clear plastic till you can see the bulbs. The whole cluster does not have to come off. The only tricky part is pulling ou the old bulbs. They are recessed pretty far back. I used a needle nose to grab them and pull them out. Then did the same thing with the new leds to push them in. Thats it! Its pretty simple. I wouldn't worry too much.
Old Jun 7, 2007 | 05:21 PM
cooltc2004's Avatar
Car: 1992 Firebird
Engine: 3.1L V6
No my car was off, on a list, getting its suspension upgraded at the time (was putting on bigger sway bars). I plugged in the battery JUST for that shot.
Old Jun 7, 2007 | 05:31 PM
AdmAnt13's Avatar
Like i said..my camera sucks. That or red is brighter than blue.
Old Jun 7, 2007 | 07:09 PM
Z.ROC28's Avatar
Car: 1991 Camaro RS
Engine: 305 L03 TBI
Axle/Gears: 4th Gen 10 bolt posi / 3.43
I was interested in doin this also... But my problem is my car is a 91' and has the yellow face lettering in the interior. I'd like to find some white faceplates for my car but i cant find any decent ones anywhere. Anyone know where I could find some?
Admant13: Off topic but i noticed your interior picture on your sig and saw your fourth gen console mated with the third gen dash... I was planning on doing that but I didn't wanna lose the dash because I love the way they appeal to the interior. How hard was it to get your console to mate up?
Old Jun 7, 2007 | 07:16 PM
iamtheantirice's Avatar
red def shows up better than blue. i've done light shows for bands and whatnot but we had incandescent bulbs; needed 5 blues to match the same effect as 2 reds.
-Chris
Old Jun 7, 2007 | 08:19 PM
krisb410's Avatar
Red also shows up better than amber.
Old Jun 8, 2007 | 07:45 AM
AdmAnt13's Avatar
Well heres the thing, 4th gen console match up ALOT better in Firebird/Trans Ams than in Camaro's. I haven't seen an install I liked yet into a third gen camaro. Basically the Radio pod portion is different from the Pontiac's which makes it incompatible...unless cutting is done and such. Don't get me wrong, it can be done..but not easily.
-Chris
Good to know....thanks.
Old Jun 15, 2007 | 10:23 AM
SK_1983-TA's Avatar
I just put in the White Face Gauge Overlays and the gauges now are white and look awesome. I want to change the bulbs to leds and according to what people have suggested I will go with the 5 leds that have the one bright in the middle and the 4 around I guess it has a wider span. Anyway I am now just trying to figure out the color led to put in. I saw the pics of the red ones but the pics seem to be with the origial black.
Does anyone have the white face gauge overlays and use color leds so that I know what they would look like with them? I saw the pics of them on the whitegauges.net but I wanted to see if that is really what they would look like. I was thinking about the white leds because I really like the look of the white gauges.
If anyone has these white overlays and leds let me know what they think or post pics if you have them, thanks!
Old Jun 18, 2007 | 02:33 PM
Z.ROC28's Avatar
Car: 1991 Camaro RS
Engine: 305 L03 TBI
If you don't mind me asking, where did you get your white face plate at?
Old Jun 18, 2007 | 08:26 PM
SK_1983-TA's Avatar
I got them off of ebay but this is the website http://whitegauges.net/
They were $20
Old Jan 18, 2010 | 10:37 AM
temper_loks's Avatar
Car: 1989 Camaro RS
Transmission: Automatic Trans
Hey there my first post!!
I checked out the superbrightleds.com page SWEET!! they have everything except the 561 replacement bulb or does anybody know if theres one on that page that can replace the 561, its the one that goes in the dome light and the rear cargo light Thanks in advance
Old Jan 18, 2010 | 11:00 AM
AdmAnt13's Avatar
Talk about resurrecting an old thread. I don't even drive my third gen daily anymore. Garage kept and used for shows. I have a 2001 WS6 to play around with these days.
Looked for you but didn't see that superbrightleds had a replacement for that. I would check eBay. They have LED circuit boards with an adapter that I know will work.
Old Jan 18, 2010 | 11:13 AM
Car: 1989 Camaro RS
Thanks man really greatful for the answer.
Old Jan 18, 2010 | 05:28 PM
krisb410's Avatar
I got my replacement LED dome light from them. They are under the Festoon bulbs section
Old Jan 18, 2010 | 11:52 PM
ThreeOhFive's Avatar
Car: BMW 330i ///M Sport
Engine: M54 DOHC I6
Transmission: 5 speed
Axle/Gears: Stock
I kind of wanted to do red guages, ac, courtesy lights, and footwell lighting, kinda get a "Red October" submarine feel going on at night lol.
Old Jan 19, 2010 | 08:42 AM
Car: 1989 Camaro RS
But was it the replacement for the 561? Or can you send me the model number that you bought. and does it illuminate good?
Old Jan 23, 2010 | 08:46 PM
Zainan's Avatar
Car: 1990 RS
Engine: 305 TBI
Transmission: automatic ***sigh***
temper_loks I got a blue LED kit from autozone about a week ago for $15 that comes with adapters for the dome and tail lights. I'm at work for the next 36 hours so I cant give you the brand name of it beings the packaging is in the trash in my garage. It was with all the ***** ground effect lighting stuff. They come in red and blue.
Old Jan 23, 2010 | 09:57 PM
MSRed91Camaro's Avatar
Car: I have a 91 Camaro RS
Engine: 383 stroker
Transmission: Stock automatic 700r4
Axle/Gears: I have 3.73 Gears with a Eaton posi
theres some great info here
Old Jan 23, 2010 | 11:11 PM
Zainan's Avatar
Car: 1990 RS
Engine: 305 TBI
Not bad for a dead thread lol
Old Jan 24, 2010 | 10:29 AM
Zainan's Avatar
Car: 1990 RS
Engine: 305 TBI
Here is the packaging of the lights I'm using for my dome and trunk. I also have their pod lights for under the dash for floorboard lights. If I remember I will post a pic of the lights tonight.
<a href="http://s949.photobucket.com/albums/a...t=100_0258.jpg" target="_blank"><img src="http://i949.photobucket.com/albums/a...r/100_0258.jpg" border="0" alt="Photobucket"></a>
I can't get the pic to show up. Here is thee link. Sorry.
Last edited by Zainan; Jan 24, 2010 at 10:33 AM. Reason: trying to get the pic to show instead of just a link
Old Jan 25, 2010 | 02:35 PM
Car: 1989 Camaro RS
Much appreciated Zainan thanks for the info and everyone else that has left their thoughts and opinions
OLDYELLR
Car Audio
Sep 30, 2015 07:10 PM
Fronzizzle
Aug 19, 2015 01:36 PM
tnrednneck
Aug 13, 2015 08:57 AM
Omega
Aug 10, 2015 12:46 PM
apie2546
Aug 8, 2015 07:12 AM
