T-Top sunshades
Old Jun 13, 2007 | 01:04 AM
LIL BASTARD's Avatar
Car: 1985 Berli
Axle/Gears: stock Berli
T-Top sunshades
I've never seen what they look like. Does anyone have a pic? I searched and didn't come up with anything. So I made my own, and I was just curious as to how close my design was to the factory part.
I used a 3oz mat, fierglassed it off a cardboard template I made. 1 edge I sanded to a edge and wrapped in felt so it slipes behind the plastic trim and glass, holds it tight to it, dont make any noise and the other side on the top I used small weather strip so it seals against the glass and the original weather strip. Befoe I put the weather strip on I sanded it smooth and painted it black. It don't vibrate or make any rattling noise, even with the stereo on and going over bumps. It still seals nice and tight, put the garden hose on top of car and no drips or leaks. It really does help keep the car cooler and in the Vegas heat that is a good thing. The only down side is, if I want to take the shade off I have to remove the t-top, slide it out and put the t-top back on, the plus side is, they stores in the t-top bag, and they fit in the bag with the t-tops. I'll post pics soon. Any comments?? So how close to factory is my design??
Old Jun 13, 2007 | 05:28 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
Re: T-Top sunshades
I've got a couple pics in my headliner tech install page:
http://www.iroczone.com/technical/headliner/
From the sound of it, yours are somewhat similar, except that the stock ones (as well as the aftermarket ones like I'm showing) don't have any sort of weatherstrip around them.
Old Jun 13, 2007 | 10:00 AM
LAFireboyd's Avatar
Axle/Gears: 9-bolt/3.45
Re: T-Top sunshades
Here's a set of factory sunshades right out of their original box, so their still like brand new... 20 years old. I've never even looked at them until now!
The top face has a black vinyl(maybe paint) coated surface(prolly thin cardboard); there are a couple of stick-on velcro pads for attachment(to the glass, I'd guess); the underside has the padded headliner material; there's a nylon binding stitched around the perimeter; and the total thickness of each shade is about 3/8"-1/2".
Old Jun 13, 2007 | 02:18 PM
Pocket's Avatar
Car: 91 Trans Am
Re: T-Top sunshades
I didnt know those little velcro tabs were factory
I peeled them off my t-tops when the shades went into long term storage
Old Jun 14, 2007 | 11:42 AM
flippermtc's Avatar
Car: 88 IROC T-Top
Engine: 5.7
Transmission: Automatic
Re: T-Top sunshades
Modern Day Muscle has the hard plastic type. GM NOS. Expensive but very nice and moisture dosen't effect them. I just put them in my IROC.
Old Jun 14, 2007 | 01:13 PM
online170's Avatar
Car: 1987 Firebird
Engine: 355
Re: T-Top sunshades
LAFireBoyd, THANK YOU SO MUCH!!! I park my car at work, and by the endof the day its a frikin oven. I didnt realize those things were sunshades, i figured they are just padding for the two t-tops when you store them in the back to avoid glass on glass contact. BUT it all makes sense now!
Im using them starting tommorow!!! Thanks again.
Old Jun 14, 2007 | 04:15 PM
1bad86's Avatar
Car: 1986 IROC-Z
Engine: 305 T.P.I.
Re: T-Top sunshades
Wow, I did not even know they had those from the factory i just made mine..
Did all t-top cars come with them or was it an option??
Old Oct 18, 2009 | 06:35 AM
KITT1983's Avatar
Car: 1983 Pontiac Trans Am Daytona 500
Engine: Crossfire 305ci V8
Transmission: Jasper 700R4 4 speed Automatic
Axle/Gears: 3.23 limited slip/posi
Re: T-Top sunshades
I have the GM NOS hard plastic sunshade
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
1Aauto
Sponsored Vendors
Jan 15, 2016 06:26 AM
Thirdgen89GTA
Nov 26, 2015 11:04 PM
meeklay812
Oct 1, 2015 03:46 PM
1Aauto
Sponsored Vendors
Sep 10, 2015 02:02 PM
