Steering wheel question
Car: 1989 GTA
Axle/Gears: 3.23s
http://www.hawksthirdgenparts.com/Pr...ringwheels.jpg
Does anyone know what year and type F-body the bottom most steering wheel in that picture was equipped on. I'm interested in finding one and swapping it in to replace the GTA one I have with radio controls since I'm fairly certain you can't get the radio controls to work with a modern deck. That and I really prefer 3 spoke steering wheels.
Re: Steering wheel question
Kinda looks like the earlier (pre air bags) Trans Am wheel. The one on the top left I know is from a camaro, my 84 Berlinetta had one.
http://cgi.ebay.com/ebaymotors/82-90...QQcmdZViewItem
Car: 1989 GTA
Axle/Gears: 3.23s
hmmm, looked better in the small picture heh heh. I've never actually swapped a steering wheel out before, how do I know if a steering wheel will fit or not? Is it possible to use one from a 2nd gen like this one.
http://static.howstuffworks.com/gif/70ta_03.jpg
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
the top left one sure looks identical to my 82 trans am one
you can put any gm wheel you want in it even a truck one the splines are the same on all gm across all divisions and years from at least the 60s to 90s years and all models
but whether it will clear the housing is another story
good luck
good luck
Car: 1989 GTA
Axle/Gears: 3.23s
good luck
good luck
And do these two steering wheels look the same?
http://cgi.ebay.com/ebaymotors/ws/eB...m=280131372419
http://cgi.ebay.com/ebaymotors/TRANS...spagenameZWDVW
Engine: 4.3L Z TBI
top of the steering column housing
where the turn signal switch and steering lock plate and such are housed
the f body steering wheels have a longer skirt on the wheel hub than other makes and models
other vehicles have a really short skirt on the wheels
compared to these cars
at least the early birds do anyways
good luck
good luck
Car: 1989 GTA
Axle/Gears: 3.23s
Guess i'm going to have to do some research on whether or not a 2nd gen wheel will fit on a 3rd gen column.
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Hope that helps !
Car: 1986 pontiac firebird
Engine: 2.8l v-6
Transmission: 5-speed
Axle/Gears: stock
thats off a base modle car both my 85 and 86 have that wheel if your in pa i have one if you want it
Car: 87 GTA
That bottom is what is on my 87 GTA.
As for the radio controls, Crutchfield sells an adapter to use the steering wheel controls, with an aftermarket radio. I've heard some Alpines can use them like stock, but I dunno which models.
Engine: LS1, LB9, L03
A 2nd gen wheel will fit and look awesome (as long as we're talking about the Formula wheel standard on all Formula's and T/A's). Those things are expensive though, I've seen them go for over $200 on ebay in good shape.
Car: 1989 GTA
Axle/Gears: 3.23s
http://cgi.ebay.com/ebaymotors/Ponti...QQcmdZViewItem
Car: 1989 GTA
Axle/Gears: 3.23s
Well I might go ahead and bid on that wheel. So for sure a 2nd gen formula wheel will fit, has anyone done it before? I'de really like to know before I hock out $120.
backtothe80s
Sep 5, 2015 12:39 AM
