Lock Plate is a PITA!
Old Jul 8, 2007 | 06:43 PM
Morder.'s Avatar
Car: 20 M550i xDrive
Engine: LB9 305 TPI
I've dumped enough money in this car to the point where I'm not going to spend $38 on a tool and $28 for a lock cylinder. How can I take this damn thing off without purchasing the tool?
Old Jul 8, 2007 | 08:45 PM
cooter26's Avatar
Car: 83 Camaro
Engine: 383
Axle/Gears: 4th gen 10 bolt 3:42 POSI
Re: Lock Plate is a PITA!
Autozone rents the tools for cheap and Item No: LC14280
$9.99 Each
is the price for your lock at Orileys.
Old Jul 9, 2007 | 11:09 AM
DillonRager's Avatar
autozone rents fior free i just fixed mine
Old Jul 10, 2007 | 08:30 PM
Morder.'s Avatar
Engine: LB9 305 TPI
So I got the tool and now the lock ring wont friggin come out. There isn't a tool for that too is there? I figured 2 screw drivers would do the trick
Old Jul 11, 2007 | 10:13 AM
i just used 2 screw drivers
Old Jul 11, 2007 | 04:21 PM
Pocket's Avatar
Car: 91 Trans Am
Ive removed the lock plate by mashing it down with my thumbs and having a helper pop the ring off with screwdrivers
Its VERY hard but do-able
I did 2 like that until I dropped the $30 on the tool
It is VERY worth it
You could jsut buy a JY column and disable the VATS system if you havent already
Old Jul 18, 2007 | 10:35 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
try harder
i can remove these without the compressor but its tricky but ive had to many times, i own two of the lock plate compressors though
also try a hooked round sharp handle pick if the little screwdrivers dont work,
they have to be thin and small to get inbetween the shaft and the ring
slide it up the shaft when its out of the groove, onto the end of the part of the tool that screws onto the shaft end
leave it on the tool until reintallation time
although i never reinstall thelock plate on my own vehicles but it do on customers vehicles, car theft is a RARE thing here, maybe three or four a year around here, and evne then its not TRUE car theft,
good luck
Old Jun 14, 2008 | 05:06 PM
80schild's Avatar
Car: 87 GTA
Engine: 5.7 TPI
Axle/Gears: 3:27 BW 9 bolt
I know this is an old thread but I have a question. I have my wheel off and now I need to remove the lock plate. There is a plastic cover over the lock plate, am I supposed to remove it somehow first? It looks like it will crack if I use my tool on it.
Old Jun 14, 2008 | 10:06 PM
Randy82WS7's Avatar
Engine: 4.3L Z TBI
the plastic is part of the plate it does not come apart
depress the entire plate assembly to get the hog ring off
there is a spring under the plate and horn contact thing it preloads the upper column bearings in the upper housing assembly
Old Jun 15, 2008 | 08:45 AM
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
The ones I've taken apart had a black plastic cover over the lock plate that had to be removed first. It just snaps off.
Old Jun 15, 2008 | 11:15 AM
80schild's Avatar
Car: 87 GTA
Engine: 5.7 TPI
I got it off with the plastic on it, it didn't hurt anything.
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
Hotrodboba400
Dec 10, 2019 07:07 PM
13sec83trans
Carburetors
22
Nov 28, 2015 09:26 PM
83 Crossfire TA
Sep 8, 2015 12:06 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
