A/C Vent trouble... Stuck in one setting.
Old Jul 20, 2007 | 09:42 PM
nelapse's Avatar
Car: GTA
Engine: 383 HSR
Transmission: TH-700R4
My vents are stuck on the setting where the cool air blows out of the dash pad. I pulled out the HVAC and the vacuum switch is all connected so WTF?
How can I rig it to blow out only through the front of the dash? Can I just connect two of the hoses to rig it?
Any ideas?
-Cale
Old Jul 21, 2007 | 01:18 AM
Slepewesel's Avatar
Car: 91 Camaro Z28
Engine: 5.0 TPI (LB9)
Transmission: 4L60
Re: A/C Vent trouble... Stuck in one setting.
Why "rig it"? If memory serves me, when there is a vacuum leak, the system defaults to the Defrost setting. Me thinks you have a vacuum leak somewhere.
Old Jul 21, 2007 | 06:02 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Slepewesel is right: the defrost setting is the default. The vac control switch is often to blame. Put your ear close the right side of the control and give a listen.
https://www.thirdgen.org/forums/atta...duct010707.jpg
JamesC
Old Jul 22, 2007 | 11:52 PM
Mustang Killer's Avatar
Car: 89' Firebird Formula
Engine: 305ci
Axle/Gears: 3.76
When I was working on my distributor, replacing the rotor, I had noticed that one of the vacuum lines that was beside the distributor had a hole in it. I talked to my uncle and my father about it and they said that on a firebird, that vacuum line is the common problem because of heat and rubbing. I'd check it out and see if that isn't the problem.
Old Jul 23, 2007 | 08:35 AM
nelapse's Avatar
Car: GTA
Engine: 383 HSR
Where can I buy a new Vacuum switch?
Old Jul 23, 2007 | 08:56 AM
JamesC's Avatar
I "believe" this is what you need: Valve Vac Sel GM part # 16032395. The number is good on GMPartsDirect.
JamesC
Old Jul 23, 2007 | 09:24 AM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
Yep, mine was hard and cracked right where it goes into the loom with the wiring that goes into the car. I've had defrost only for the past 2 years.
tmellott89
Oct 14, 2015 02:06 PM
Briandrex
Oct 5, 2015 06:20 AM
Fanatic1074
Oct 2, 2015 03:47 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
