headrest removal
Old Jul 31, 2007 | 08:58 AM
redfire82's Avatar
Car: 84 camaro s/c
Engine: 305 slightly tweaked
Transmission: TH400
Axle/Gears: 3.42 single stripe
headrest removal
I have some fourth gen seats that I want to recover but I can't get the headrests to come off the seatback on my thirdgen or fourthgen seats. Has anyone ran into this problem before and if so how did you take them off?
Old Aug 3, 2007 | 11:23 AM
redfire82's Avatar
Car: 84 camaro s/c
Transmission: TH400
Re: headrest removal
ok I got the thirdgen style off with a breadknife jammed down the slot, however the fourth gen style has two rails and no slot so I'm kinda stuck again.
Old Aug 3, 2007 | 11:21 PM
shr00m's Avatar
Car: 1992 Jade Green---Trans Am Converti
4th gen's have a spring like wire clip around the bottom of the plastic peg they slide into. Unless you have the special tool from GM, you will have to remove the rear plastic piece at a minimum. You might have to remove the hog-rings from the upper portion of the rear cover as well, but if you are recovering it you will have to anyway.
Kevin D.
Old Aug 29, 2007 | 06:06 PM
RmeanyMAN's Avatar
I am trying to put new seat upholstery in my 87 iroc and everything was going fine but now I can't seem to get the headrests off the seat to fisish the job. can anyone give me some advice on how to remove the headrests from the seats? Thanks
Old Sep 24, 2010 | 03:59 PM
turtlevsrabbit's Avatar
Im trying to figure out how to get an 87 formulas headrests off as well.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
HP52TA
Feb 3, 2018 10:51 PM
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
ctoledo0834
Sep 18, 2015 04:16 PM
Stroopwafel
Sep 11, 2015 06:38 AM
