My roof console
Old Aug 8, 2007 | 08:22 PM
Orinackra's Avatar
Car: 06 SRM M6 GTO, 98 Grand Prix GTP
My roof console
I finally got around to getting my headliner installed, and I installed a roof console as well. Came out of a late 90's Blazer. Has a compass, thermometer, avg speed, fuel consumption, trip computer.... but right now the only thing that works is the compass. I have to go back to the junkyard and get the sensor for the temp, and I'm not sure what need to do to get the fuel and odometer functions to work. The lights work independently of the dome lights so they dont come on unless you tap them. Not too bad for 6 bucks though I'd say!
Sorry for the horrible pic quality, my camera phone seems to take worse and worse pics as time goes on.
Attached Thumbnails My roof console-sspx0776.jpg   My roof console-sspx0777.jpg   My roof console-sspx0778.jpg
Old Aug 8, 2007 | 08:40 PM
blue82_z28's Avatar
Car: 1982 Camaro Z28 w/ RS groundfx
Transmission: Tranzparts 700r4
Axle/Gears: 3.23's
Re: My roof console
that's awesome, it looks great. i want one now, lol
Old Aug 10, 2007 | 01:45 AM
HCR13's Avatar
Car: 1987 Trans Am
Engine: 355ci L98 soon to be turbo'd
Axle/Gears: 2.73 posi
Re: My roof console
thats very trick, a 90's blazer? I think I'm going to have to find me one...
Old Aug 10, 2007 | 05:44 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: My roof console
Should you get everything to work, a how-to would be very nice.
JamesC
Old Aug 12, 2007 | 02:28 PM
Orinackra's Avatar
Re: My roof console
for sure. I have the wiring here, but it makes no sense.
For the lights, the orange wire was for power, and the black was ground.
I'm gonna get the rest hooked up sometime soon tho.
Connector Part Information
  • 12064980
  • 9-Way F Micro-Pack 100 Series (BLK)
Pin
Wire Color
Circuit No.
Function
DK GRN
1301
RAP Fuse Supply Voltage
BLK/WHT
451
Ground
DK GRN/WHT
817
Vehicle Speed Signal
LT GRN/BLK
735
Outside Air Temperature Sensor Signal
GRY
1220
Instrument Panel Lamp Fuse Supply Voltage - 2
PPL/WHT
1382
LED Dimming Signal
Not Used
ORN
40
Battery Positive Voltage
YEL
1127/1132?
Trip Computer/Nav Class 2 Serial Data
  • 12064762
  • 6-Way F Metri-Pack 150 Series (GRY)
Pin
Wire Color
Circuit No.
Function
A
WHT
156
Courtesy Lamp Output
B
ORN
1732
Electronic Control Unit Output - 12 Volt - Inadvertant Load Control
C
ORN
40
Fuse Output - Battery
D
BLK
1850
Ground
E
PPL/WHT
1382
LED Dimming Signal
F
Not Used
Old Aug 14, 2007 | 10:33 AM
Untamed's Avatar
Car: 88 Trans Am
Engine: 305 TBI
Re: My roof console
Could the display screen slide free of the plastic housing? Best guesstimate. For those of us with the 3rd gen overhead consoles, removing the date/time wheels on the overhead console and putting in a compass / temp digital display would be awesome. Just need something small enough to fit.
Very inventive. Definately stirs the creative juices.
Old Aug 14, 2007 | 03:53 PM
Orinackra's Avatar
Re: My roof console
I see no reason why that wouldnt work. You'd have to figure out new buttons, as the grey buttons are part of the exterior, but the rest of all that does come free. I was actually messing with that, because I want to change the blue display to red somehow.
Old Aug 14, 2007 | 07:43 PM
1989karr's Avatar
Engine: 3.4 / 5.0
Transmission: 700-R4
Axle/Gears: 3.42 / 3.42
Re: My roof console
That looks AWESOME! How may I ask did you mount it???? I realyl wanted to do that, perhaps mount some gauges or something in one but mounting the console is my main concern about these things.
Old Aug 14, 2007 | 08:37 PM
Orinackra's Avatar
Re: My roof console
Well, in the blazer theres a single screw that goes into a brace that runs down the center of the roof. On mine, I put two, one in front, one in back, just drilled into the center bar. Theres a big plastic bracket that has the compass attached. Then the outer part that you see snaps on, using metal clips just like what hold the radio trim on. And theres a single screw near the windshield side that holds it even tighter.
Old Aug 14, 2007 | 10:17 PM
1989karr's Avatar
Engine: 3.4 / 5.0
Re: My roof console
ahhh ic ci thanks for the insite. I saw a counsel in an older Blazer that I thought looked pretty cool. i was thinking of adding that somehow. I will definetley look in to it. Again, yours looks great!
Lbibb
May 5, 2016 12:00 AM
LC2 TECH
Oct 13, 2015 11:53 PM
FormulaEngland
Sep 30, 2015 01:50 PM
formula00ra
Interior Parts Wanted
Sep 28, 2015 11:50 AM
ndndndnd
Sep 28, 2015 08:00 AM
