if it aint broke......... dont fix it!
Old Aug 10, 2007 | 10:27 AM
bigchief's Avatar
Car: 1989 Firebird Formula
Engine: 5.7L 355 TPI
Transmission: 700 R4 with TCI rebuild kit and valve body mods
my vents dont work right anymore! (front/defroster/feet)
i know that my vaccum lines are fine because when i remove them from the unit in the dash, and connect vaccum manually, the vents all work perfect.....
there are 2 pieces that the hoses plug into, the right hand side controls the vents, and the left hand side controls the hot/cold
i've actually been tyring to figure this out for a while, i took mine apart and now i cant get it to work how it used to...... i took it apart because there was a piece of plastic broken and i wanted to see how it worked
has anyone had this problem with these stupid vents???
Old Aug 11, 2007 | 05:59 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: if it aint broke......... dont fix it!
Nearly everyone . Often the vac control valve is the culprit (the piece with the 'fingers/nipples' in the following pic:
https://www.thirdgen.org/forums/atta...duct010707.jpg
JamesC
Old Aug 11, 2007 | 10:47 AM
86NiteRider's Avatar
From: Somewhere around the South Side of Chicago just crusin' in one of the Niteriders
Car: 92RS 25th Anniv./88 IROC Z28 Vert
Engine: 305 TBI w/Tpi Air / 305 TPI
Transmission: 700r4/700r4
Axle/Gears: Posi
It usually happens when the factory radio is removed and an aftermarket raido is installed. I think the vac line get disconnected when reinstalling the radio.
Old Aug 12, 2007 | 01:47 AM
bigchief's Avatar
it has nothign to do with the radio......
jamesC, how can i fix it? is the thing not sealing correctly now since i took it apart??? should i get it from the dealership???
Old Aug 12, 2007 | 02:01 AM
toxik IROC's Avatar
Car: 1987 Camaro
Engine: 350 hsr
Transmission: 700R4(blown)
Axle/Gears: 3:73
i wana know too
Old Aug 12, 2007 | 05:26 AM
JamesC's Avatar
While the JY is a possibility, a new one would be the better call. Check with your dealership.
JamesC
Old Aug 12, 2007 | 04:14 PM
bigchief's Avatar
well is it just the REAR piece thats the problem or the rubber piece in side with all the passages indented on it????
Old Mar 19, 2009 | 12:18 PM
bigchief's Avatar
felt like bringing this one back to life.... still have the problem, couldnt find the part. any easy solutions?
Old Mar 19, 2009 | 08:33 PM
vette gator's Avatar
Car: 85 Z28
I was able to find a replacement at Carquest a few months ago (part #207708). I think they had it under "vacuum control valve" or something similar.
Old Mar 25, 2009 | 11:53 AM
bigchief's Avatar
is that just carquest.com? i dont see where to go on the main page, can you guide me? or should i give them a call? i dont have one of these stores by me
Old Mar 26, 2009 | 09:20 PM
Car: 85 Z28
I've never had any luck with a Carquest web site - I've always had to go to an actual store. I don't know if they sell over the internet, but it might be worth calling them to see. Other parts stores probably stock these as well, it's just that I usually go to Carquest.
Old Mar 27, 2009 | 10:12 AM
bigchief's Avatar
ok man, i found one in my area actually. i'll check it out, thanks a lot dude
Old Mar 31, 2009 | 10:15 PM
Awesome-X's Avatar
Car: 87 Camaro
Anyone found one yet? Have a part number?
Old Mar 31, 2009 | 10:18 PM
tony_cogliandro's Avatar
Car: 1990
Axle/Gears: stock
were you under the dash just before this happened? getting the hoses hooked up is a biach. do you still hear the fan? if you do its probably the vent hookups and not the controller.
Old Apr 1, 2009 | 03:59 PM
bigchief's Avatar
its not the hoses. thats why i said i plugged them manually and they worked fine.... its the control thats messed up
Bubbajones_ya
Oct 25, 2015 08:01 PM
Reid Fleming
Oct 10, 2015 09:56 PM
dusterbd
Sep 29, 2015 08:40 AM
z28joe2
Sep 28, 2015 05:54 PM
mfp189
Sep 27, 2015 09:25 AM
