interior lights
Old Aug 28, 2007 | 12:13 AM
ruberbanman126's Avatar
Car: 1992 Camaro RS, 1999 GMC Jimmy
Engine: 305 TBI, 4.2L I6
Transmission: 700R4, 4L60-E
Axle/Gears: 10 Bolt 2.73, 10 Bolt Posi 3.42
interior lights
i have a 1992 camaro rs and i was wondering if there is any way to turn off the interior lights, when the doors are open so i dont kill my battery?, can any one help me with this?
Old Aug 28, 2007 | 05:32 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: interior lights
Under normal circumstances, such as cleaning the interior, leaving the doors open shouldn't present a problem. A much longer period? Unhook the battery (a two-minute job).
JamesC
Old Aug 28, 2007 | 06:13 AM
KYLE87's Avatar
Car: 1987 Camaro
Engine: 5.7
Re: interior lights
When you open the door from the inside look in the open space at the front and there are little door pins, you could undo the wiring to where the pusher does nothing,or you could just tape the pin down so if you decided you wanted it back you just haft to undo tape. If you have a Car alarm I wouldnt do either because most alarm triggers use these pins.
Old Aug 28, 2007 | 08:11 AM
naterman35's Avatar
Car: 89' Camaro RS--
Engine: 305--
Transmission: Automatic
Axle/Gears: 2.73--
Re: interior lights
Umm. How long do you plan on having your doors open?.
BRoss99
Aug 10, 2025 05:08 PM
Vintageracer
Jan 10, 2020 05:33 PM
The_Phoenix
Feb 4, 2016 07:10 AM
Omega
Aug 10, 2015 12:46 PM
