Power windows > manual windows
Old Sep 2, 2007 | 05:02 PM
badinfluenceRS's Avatar
Car: 1994 Trans Am - 1992 Firebird
Engine: LT1 5.7 V8 - 3.1 V6
Axle/Gears: 3.42 / LSD
What is needed to do this?
Just the handle w/ gear attached to it?
I replaced my power window motor, and it still does not work. Switch is functioning how it's supposed to and it's sending power but it still does not work...
any other ideas?
Old Sep 2, 2007 | 05:28 PM
ntomsheck's Avatar
Car: 1989 GTA
Engine: 350TPI w/ Speed Density
Axle/Gears: Borg warner 3.27
Re: Power windows > manual windows
Window could be jammed. Or you have bullet proof glass.
Try pulling the motor out and try pressing up or down on the switch to see if the motor spins unloaded. For manual, you just replace the power motor assy. with a manual. Find the manual(s) in a junkyard.
Old Sep 2, 2007 | 05:37 PM
jammed is possible...
it went down but wouldn't go up...and I can neither push nor pull the window to move it...
how do i "un jam" that sum bitch
Old Oct 2, 2007 | 06:13 PM
Psycho_91Camaro's Avatar
Car: 1991 Camaro RS
Engine: THE LT1 SWAP SHALL BEGIN!!!!
Transmission: 700 R4
Axle/Gears: LSD! =(
I bought a 1990 Chevrolet Camaro RS to swap the fron bumper cover/fenders/hood and driver side door! now my passenger side door is the only door with the automatic feature! while my drivers side door is manual!
jaridjohn
Jul 8, 2024 03:49 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
sailtexas186548
Aug 24, 2015 10:11 PM
stalkier
Aug 21, 2015 01:54 AM
