HELP, will a 92 t-top headliner fit my 84?
Engine: 305tbi
I have an 84 camaro, and I may be buying a headliner for it tonight from a 92 rs. I know the latches are different on an 84 and a 92, but will the headliner fit????? need to know this asap, thank you!!!!!
Re: HELP, will a 92 t-top headliner fit my 84?
im almost positive that it will fit, as long as both cars came with the factory t-top setup and not the C&C setup.. easiest way to tell the difference between the two is with the C&C setup theres a larger gap between the ttops and the front windshield
Car: 2015 Chevy SS
Engine: LS3
Transmission: 6L80E
I have a 92 firebird with C&C tops, I bought a new headliner for it (the abs kind) and I went to install it...it didnt fit at all!
Make sure you have factory ttops and then you should be ok.
ambainb
Apr 25, 2016 09:21 PM
1Aauto
Sponsored Vendors
Aug 24, 2015 03:40 PM
