1986 TRANS AM HORN ISSUE
Old Sep 14, 2007 | 10:50 AM
kerns1984's Avatar
MY HORN DOESN'T WORK ON MY CAR. HOW DO I FIX IT?
Old Sep 14, 2007 | 10:58 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
Re: 1986 TRANS AM HORN ISSUE
That would depend on the problem, so your first job is to diagnose the issue to determine the problem.
Check the fuse first. Next, get a multimeter or test light, and touch the terminal on the horn while somebody blows it. That'll tell you if there's power getting to the horn. If not, then try testing the output of the horn relay. If not that, then test the wire going to the horn pad on the steering column.
Old Sep 14, 2007 | 11:08 AM
kerns1984's Avatar
THANKS
Old Sep 14, 2007 | 12:57 PM
kerns1984's Avatar
I got it fixed ......thanks
Old Sep 14, 2007 | 01:49 PM
Jim85IROC's Avatar
care to elaborate on the problem so that others who may have similar problems can learn?
theshackle
Sep 17, 2020 08:26 AM
transamgta1Khp
Aug 17, 2015 12:18 PM
mizz0313
Aug 12, 2015 06:45 AM
Keiffer76
Car Audio
Aug 9, 2015 11:37 PM
Leggman1
Aug 6, 2015 04:15 AM
