moved:hows horn wire attach?
Car: 91 formula
Engine: 350 tpi
Transmission: auto
Axle/Gears: poss
i am trying to put orignal camaro steering wheel back in my car,i bought the little yellow horn wire ,and i can see how the one side goes into the little round white part ,but how does it attach to the wheel i dont see a tab or anything.thanks .i found out its called the horn contact wire.
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Re: moved:hows horn wire attach?
The wire should connect to the horn pad - not the wheel.
Car: 91 formula
Engine: 350 tpi
Transmission: auto
Axle/Gears: poss
i ve looked on the pad there is no place for it to plug into. i think the end with the spring attaches into the turn signal cancel. there is still no place on the pad to plug into.
Car: 91 Camaro RS
Engine: Small Block
Transmission: TH350 w/ 3000 stall convertor
Axle/Gears: 3.73 w/ powertrax locker
theres one that connects to the turn signal cancel which is a contact point for when you push the horn button down. The other one is just a ground point
1992 Trans Am
May 10, 2023 07:19 PM
dustint209
Sep 9, 2015 08:09 AM
db057
Aug 11, 2015 10:11 PM
