84 rear split seats in an 89?
Old Oct 22, 2007 | 05:58 PM
82 Iron Duke's Avatar
Car: 04 Silverado
Engine: 4.8
Transmission: auto
I was wondering if anyone has done this swap. I just bought some 84 TA seats and have already added the bar on the hump, now here’s my problem. My car has the shoulder belts and the 84 seats were set up for lap. I took apart my 89 rear seats and the mod looks nearly impossible to add shoulder belts to 84 seats? I guess I can add lap belts to my 89 but that leave those big boxes in the rear that hide the shoulder belts. If you have done this successfully or have and ideas or opinions I would appreciate any and all feedback.
Old Oct 22, 2007 | 07:38 PM
JeremyNYR's Avatar
Car: 1984 Trans Am
Axle/Gears: 10 bolt w/ 4.10 gears
Re: 84 rear split seats in an 89?
you can get split rear seats from a later car (my friend's 91 has them) which are tapped for the rear shoulder belt loop. Swapping your seat covers over to those would be the easiest way without swapping the plastics for lap belts. Then again, do you really need the little loop to hold the rear belt? they probably aren't used that often and will work just fine without them.
Old Oct 22, 2007 | 07:48 PM
Car: 04 Silverado
Engine: 4.8
Transmission: auto
Hmmm,
Thanks Jeremy for those ideas, my mind is now at ease It just takes someone elses ideas to make things seem so simple
Old Oct 25, 2007 | 07:26 PM
RCAR7395's Avatar
From: South Bend Indiana iphone CALL OR TXT 574-607-2389
Car: 2003 GMC 2500HD Sierra Pickup
Engine: 6.0 Vortech
Transmission: 4x4
It sounds easier to swap the plastics, and will look better. But now you gotta do the headliner too.
Old Oct 25, 2007 | 07:57 PM
JeremyNYR's Avatar
Car: 1984 Trans Am
i'm glad I could help! rcar7395, why would he have to do the headliner?
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
colton_carlson
Mar 8, 2019 12:21 PM
MORREALE5
Sep 13, 2015 09:16 PM
