Temp. Guage Stuck
Old Oct 31, 2007 | 09:11 PM
85cmroz28's Avatar
Car: 1985 Camaro Z/28
Engine: L69
Axle/Gears: One-Wheel-WOnder 3.08
Temp. Guage Stuck
About a week ago, while I was starting my car, the temperature gauge got stuck wide open while the engine was cranking. Any suggestions on how to remedy this?
Old Oct 31, 2007 | 10:27 PM
Titan85's Avatar
Car: 1987 Camaro SC
Engine: 305 LB9
Axle/Gears: 3:42
Re: Temp. Guage Stuck
Well, it if got jammed against something (like the edge of the gauge), you can open up your gauge cluster and bump the needle to free it. If the gauge is shot, you can replace it with another one (cheapest I have seen: http://www.moderndaymuscle.com/inc/sdetail/1104). The gauge just has two screws to take out and then just pops out. Hope this helps
Old Oct 31, 2007 | 10:59 PM
85cmroz28's Avatar
Engine: L69
Thanks...I just wasn't sure if it would damage anything by physically bumping it.
Old Nov 1, 2007 | 06:05 AM
Titan85's Avatar
Car: 1987 Camaro SC
Engine: 305 LB9
Axle/Gears: 3:42
Nothing should break as long as its not a hard bump, just make sure the end of the needle doesn't bend very far since they are fragile
Old Nov 1, 2007 | 06:50 AM
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
In my, limited, experience if it bumped up and got stuck behind the bezel it's probably shot. Freeing it up may get it to work again for a while but it's likely to get stuck again. Check the action of the needle when you free it. It should not bounce or move freely.
sheachopper
Jul 31, 2019 11:27 AM
tmellott89
Oct 14, 2015 02:06 PM
