Pillar pod gauge A-Pillar question
Old Nov 6, 2007 | 09:32 PM
firebird896's Avatar
Car: '89 GTA/'86 TA/98 TA
Engine: 350/350/LS1
Transmission: R4/T5/4L60E
Axle/Gears: 3.23/2.77/3.73
I'm looking on Autometer.com and found these piilar pods for A-pillar. 1 says 1982-92 Camaro, Firebird (Hardtop) and the other 1982-92 Camaro (T-Top) No firebird t-top
I have a T/A t-top. If I got the camaro t-top 1 would it make any difference in fitting
2-1/16 in. is the size I'm looking for.
Old Nov 7, 2007 | 02:20 AM
The Project's Avatar
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
Re: Pillar pod gauge A-Pillar question
The Camaro T-top gauge pod will fit your TA with no problem. No trimming is required.
Old Nov 7, 2007 | 04:46 PM
Engine: 350/350/LS1
K thanks off to buy 1
Old Nov 7, 2007 | 05:57 PM
krisb410's Avatar
Car: 91 RS Camaro, 75 L82 Corvette
Engine: LO3, 383 Stroker
Transmission: 700R4, TH400
Axle/Gears: 4th gen 3.23 posi/LS1 discs, stock
I bought one of them (autometer t top pillars) for my car, I didn't like how the lower gauge sits right on top of the dash, so I just bought the one that mounts to the existing pillar. That way I could put the gauges exactly where I wanted them, not what some other guy thought where they should be. I have seen other manufacturers that have complete pillar setups that don't have the lower guage right on the dash, but it was after the fact. A search on hear should bring them up fairly quick if you don't want your gauges to sit right on top of the dash.
Old Nov 7, 2007 | 06:02 PM
loneroad's Avatar
Car: 90RS Conv.
Engine: 383 w/ small shot
Transmission: th400
Axle/Gears: moser 9in
ive seen the ttop and the hard top pillars is there any diff for the verts?
Old Nov 7, 2007 | 06:29 PM
Engine: 350/350/LS1
Where did you get it from? What was the product number?
Old Nov 8, 2007 | 03:47 PM
Engine: 350/350/LS1
Hey guys while we're on this subject what kind of gauges should I get Boost/Vacuum, Nitrous pressure, Trans temp., etc...
And what type too Cobalt, Carbon Fiber, Ultralite, etc...
Tell me what u think
Old Nov 8, 2007 | 04:54 PM
Al Hasse's Avatar
Car: 1992 RS / 1989 RS
Engine: 3.1L MFI / Vortec 383 TBI
Transmission: T5 / LS-T56
Axle/Gears: 3.42 open / 3.73 Eaton posi
I've heard that the pillars for verts and t-tops are the same.
Old Nov 15, 2007 | 05:19 PM
zride91's Avatar
Car: 1991 Z28
Engine: 383 TPI
Transmission: 700R4 w/2800 stall
I had also bought the AutoMeter 3-gauge pillar and had the same problem with the pod sitting right on the dash, it didn't even seem to want to fit in right... I brought it back.
I am still interrested in the pillar, but I have not seen any other manufacturers making them. Can you list some of the manufacturers you saw that fit better, or possibly throw on a link or two??
Thanks!!
Old Nov 15, 2007 | 06:26 PM
krisb410's Avatar
Thanks!!
Do you mean you want me to do a search for you???????
Old Nov 15, 2007 | 06:44 PM
zride91's Avatar
Car: 1991 Z28
Engine: 383 TPI
No, it's just you said you saw other manufacturers, I figured you'd enlighten me as to what you saw...
Sorry, don't worry about it.
Old Nov 16, 2007 | 12:14 AM
MNformula350's Avatar
Here's another one, I ended going with the Autometer, cause it was what my parts supplier carried, so I got my discount
http://www.gaugepods.com/
Old Nov 16, 2007 | 12:28 PM
Car: 89 IROC
If you run NOS then get the gauge. Also you might want the oil pressure and water temp.
I lke the phantom or ultra lite. You can change the bulbs on the gauges to match your car.
Frozer!!!
Jan 19, 2024 04:55 PM
Reddeath210
Oct 6, 2015 08:20 AM
redmaroz
Aug 16, 2015 11:40 PM
arod231
Aug 16, 2015 02:51 PM
89lsc
Aug 14, 2015 04:58 PM
