Tach with my 6al box
Old Nov 7, 2007 | 08:08 AM
chevrolet87's Avatar
I have an 87 SC and just got a 145 Speedo out of a Z28 of the same year. I know there is a port on the box for the tach wire to go in at, and someone else told me that there may be a resistor on the firewall where the old tach went into the coil. My question is can I just run a straight wire (of course with a fuseable link or something for protection) from the back of the cluster to the box or do i have to use factory wiring.
Old Nov 7, 2007 | 08:56 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Re: Tach with my 6al box
Click here and read MSD's instructions for GM ignitions:
http://msdignition.com/downld1.htm
The tach port on the MSD is for an aftermarket or MSD tachometer, not your factory tach in the dash. If you hook up the unit according to their directions, your dash tach should work as normal. I bought their harness and everything is great.
A search of the Electronics or Tech/General forum might reveal more topics on this subject.
Old Nov 7, 2007 | 01:57 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
The tach terminal on the box is for factory tachs as well.
$750 L98
Feb 1, 2025 02:25 PM
InfernalVortex
Apr 20, 2021 11:31 AM
Ed1LE
Sep 30, 2018 09:14 AM
Zell1luk
Sep 29, 2015 10:36 AM
Eric-86sc
Sep 28, 2015 11:37 AM
