Don't know if this is the right spot.
Old Nov 13, 2007 | 09:13 PM
dalton's Avatar
Move this if it is in the wrong section. I have a problem that when I turn on my heat, I can smell fuel coming through the vents and it is enough to make your eyes water. I turned down the fuel pressure but that didn't help so what else can I do? Do we have a cabin filter? Do you think that could be it? I can't find where the fuel could be leaking from and it holds fuel pressure for three hours going from 46 psi down to 44 1/2 psi in those three hours. Thanks for any help that you guys can give me.
Old Nov 13, 2007 | 10:08 PM
FYRCHKN's Avatar
Car: 1988 SC Convertible
Engine: LT-1
Axle/Gears: 3.23 posi w/PBR's
Re: Don't know if this is the right spot.
Are you sure it's fuel and not antifreeze?
Old Nov 14, 2007 | 06:07 AM
Kevman's Avatar
Car: 1987 Firebird Formula
Engine: 2004 LQ4
Transmission: T-5 WC
Could be an exhaust leak, or if it smells kind of sweet, a bad heater core. I have both problems.
Old Nov 14, 2007 | 07:56 PM
all4u's Avatar
Car: Firechicken
Engine: 350 + 30 over, 400 crank
Transmission: autotragic, stalled
Axle/Gears: not a one tire fire, thank god!
It's the heater core you monkey turd. Remember when you asked about the fog on the window, that's the heater core. I could hook you up with a lifetime warranty Transpro, brand spanking new for $18. Call me and I will get it for you. I still have two in stock but have four at the hub. Quit using that Blue Devil coolant fixer stuff cause I don't think that stuff works. Hit me up chump!
RazorN8
Jan 7, 2022 11:44 AM
db057
Sep 4, 2015 07:57 AM
Bubbajones_ya
Aug 28, 2015 02:17 AM
theshackle
Aug 23, 2015 03:49 PM
