Will a "Hurst Pro-Matic" shifter work in 4th gen manual console?
Old Nov 19, 2007 | 07:36 AM
ws6gta89's Avatar
Car: 1989 TRANS AM GTA
Engine: 355 L98
Transmission: Built 700r4
Axle/Gears: BW 3.27
I have a 6-speed console from a 98 trans am and was wondering if a hurst pro-matic shifter would work,i think the boot has enuff room but i wanted to ask incase anyone else has tried this ...thanx charles
Old Nov 23, 2007 | 06:18 PM
stage20's Avatar
Car: 88 iroc-z/28
Engine: 408 lsx
Transmission: 5800 stall
Axle/Gears: 4.71
Re: Will a "Hurst Pro-Matic" shifter work in 4th gen manual console?
i extensively modified a b/m quicksilver to hide in a 4th gen console.
i had to modify the shifter base, cut the frame, and make my own custom shifter handle/****.
it all turned out real nice and bolts in the factory location to the floor.
i can tell you the 4th gen console is fairly shallow inside. see if you cant get some pics of the shifter from hurst without the cover on it, or maybe some deminsions.
good luck!
1992 Trans Am
May 10, 2023 07:19 PM
Casey Meyers
Mar 2, 2016 10:46 AM
dhonda200
Aug 11, 2015 11:50 PM
THABADGUY
Brakes
Aug 11, 2015 03:43 AM
1992 Trans Am
Aug 8, 2015 08:16 PM
