B&M mega shifter for 86 camaro
Old Nov 23, 2007 | 01:45 PM
86irocguy's Avatar
Car: 1986 Iroc-Z
Engine: 350 4-Bolt Main
Transmission: Rebuilt 700R-4
Axle/Gears: 3:42
B&M megashifter for 86 camaro
well i got a B&M Megashifter for my car but i was wondering if yall could give me some pointers on how to install this kit. any advice on what to look for?and help would be greatly apprciated. thanks in advance!!
Old Nov 23, 2007 | 07:19 PM
TPI 84 Monte's Avatar
Re: B&M megashifter for 86 camaro
There should be an installation manual that came with it. If not you can get it online from B&M.
Here you go.
http://www.bmracing.com/index.php?id...subcat=1&pid=8
J
Old Nov 23, 2007 | 07:44 PM
86irocguy's Avatar
Car: 1986 Iroc-Z
Axle/Gears: 3:42
Re: B&M mega shifter for 86 camaro
is this installation fairly simple? am i going to need the relay that they are talkin about in the instructions from radio shack for the neutral/park postion that locks out the converter clutch?
Old Nov 26, 2007 | 03:48 PM
theimpaler68's Avatar
Car: 86 T/A & 88 GTA
Engine: 305 LB9 TPI & 350 LO5 TPI
Transmission: Jasper 4L60 x2
Axle/Gears: 2.77/posi LSD & 2.73/posi LSD
yes you need the relay cause it replaces the relay for the reverse/neutral safety switch. i put mine in around may so when you get it if you need help ask again. i may have a pic or two.
Old Feb 22, 2008 | 10:05 PM
Colts45s's Avatar
Car: 92 camaro rs
Engine: 350 tbi/416's/comp xe268
well you don't really need that relay. I installed the megashifter into my 92 about 8 months ago and hooked it up minus the relay"um was going to but forgot". Works fine just no nutral saftey switch but no probs
Old Feb 22, 2008 | 10:11 PM
jay_d's Avatar
Car: 84 z28
Engine: 355
Transmission: TH350
Axle/Gears: one wheel peel
when i did mine, there was a lil orange wire and a big purple wire that hooked up, the relay (to the best of my understanding) is just a novelty item......why would you want to spend money on somthing you dont need........mine came with the two relays and wont crank in gear and has back up lights......what more could you ask for?..........i will say this........make damn sure you loop the cable like it says in the instructions, and when you get it installed it WILL be hard to shift from park to rev. its normal
Old Apr 16, 2008 | 11:30 PM
Morit's Avatar
Car: Firebird 88
Engine: 406
Transmission: th400
Axle/Gears: 3.50
I am swaping V8 with 700r4 into a car that had manual trans with a V6...
And I am installing a megashifter - was cooler option than buying an old, used stock shifter
I saw that there are some sort of cables going from trasmission to the steering wheel, which I dont have, do I need to buy it..?
Is it the same thing as this neutral safety that only alows me to start an engine on parking and neutral (i would like to have it)..?
And what is that relay about? Im a bit confused...
1992 Trans Am
May 10, 2023 07:19 PM
colton_carlson
Mar 8, 2019 12:21 PM
camaro11j
Sep 19, 2018 08:49 AM
NBrehm
Aug 25, 2015 11:49 PM
mustangman65_79
Aug 13, 2015 07:36 AM
