10 Minutes to new visors!
Car: 04 Silverado
Engine: 4.8
Transmission: auto
OK, so I got tired of trying to find decent visors, buying them online and trying the junkyards
I recovered my sail panels and my C&C t-top headliner so I decided to experiment with the visors. I was going to send them out to get sewn, but I decided to try something at home first. The materials you will need are:
1- An old set of visors
2- Headliner material
3- Adhesive (I used contact cement but headliner spray could be used)
4-Poster board or any thin cardboard of your choice.
First I carefully removed the stitches from the old visors so I could reuse the cardboard as a template. (now would be a good time to inspect the plastic inserts in your visors, and replace if necessary)
[IMG]
[/IMG]
Next I traced the old cardboard and cut out a template from the poster board.
[IMG]
[/IMG]
I then traced the template on the headliner material leaving about 1/2" of extra material (I would leave more like an inch) After the material was cut I spread some contact cement on the edges of the poster board, let it dry, and folded the material over.
To finish them up I spread contact cement on the visor wood and the back of the visors I just finished, they tacked up and I pressed them together. They worked out really well, the seams are nice, and I am very happy. I just thought I would share this with you all for a quick and inexpensive fix
[IMG]
[/IMG]
[IMG]
[/IMG]
I recovered my sail panels and my C&C t-top headliner so I decided to experiment with the visors. I was going to send them out to get sewn, but I decided to try something at home first. The materials you will need are:1- An old set of visors
[IMG]
[/IMG]Next I traced the old cardboard and cut out a template from the poster board.
[IMG]
[/IMG]I then traced the template on the headliner material leaving about 1/2" of extra material (I would leave more like an inch) After the material was cut I spread some contact cement on the edges of the poster board, let it dry, and folded the material over.
[IMG]
[/IMG] [IMG]
[/IMG] Supreme Member
Car: 1991 L03 700r4 RS
Engine: 1987 WS6 Trans AM Lb2
Transmission: Th350 red neck Performance 3k stall
Axle/Gears: 95 Mustang 8.8 built with 3.73s
Re: 10 Minutes to new visors!
True hot rodder spirit here, I'm going to have to copy this one!
Car: 04 Silverado
Engine: 4.8
Transmission: auto
Thanks guys, I made an extra set and I am going to have my wife try to sew a straight stich on the bottom seam, I will post up when she is done. At least with them glued together it will be easier to sew.
Car: 04 Silverado
Engine: 4.8
Transmission: auto
UPDATE
I was not really happy with the seams, they were ok but didn't look like OEM. My wife has been really busy and hasn't had a chance to sew them so I grabbed a needle and some thread this evening and finished them. I still have an extra set for her to experiment on, but I am very happy with my results, what do you think of the final product?
[IMG]
[/IMG]
[IMG]
[/IMG] Trending Topics
Car: 89 Firebird
Engine: 6.0 LS
Axle/Gears: 3.70
hey Duke i was looking at your idea and had a thought. is it possible to just fold everything over and not glue the poater boad part to the wood panel then just sew it together or is this a must to glue to the wood? all in all i dig the idea and will use this myself as this is the one then that kept me from doing all of my own int (minus the seats).
Car: 04 Silverado
Engine: 4.8
Transmission: auto
Yes, I experimented and found the easiest thing to do was infact just glue the material over the poster board so it holds and sew it, I had a few to work with. Here is the final product installed, I also redid my headliner and sail panels.
[IMG]
[/IMG]
[IMG]
[/IMG]
[IMG]
[/IMG]
[IMG]
[/IMG][IMG]
[/IMG][IMG]
[/IMG] Thread Starter
Car: 04 Silverado
Engine: 4.8
Transmission: auto
Car: 87 GTA
My visors cost me $4 and a week. I bought a 5 gallon bucket and a box of RIT dye at Wal Mart.
I put the dye powder in, filled the bucket halfway to mix the dye powder good, dropped in the visors, and filled the bucket FULL. To the point of overflowing, so it leveled out at the VERY top.
6 days later, I pulled them out, let then air dry 2 days, and now I have black visors! Just did a set for my buddy too.
Of course, this only works if they are in good condition, and you don't like the color. Ours were tan.
Car: 87 Silver Formula
nice work and exactly the way to make new visors.We have an upholstery shop and use this method to make new visors.
for the guys who want to do their headliners,once you have the headliner out of the car,pull the old material off and then use a wire brush to wipe the old foam off the board before gluing in the new material.If you do not scrap the old foam off,the new one will look like doodoo and not stay up.
We will be redoing the interior in our formula and i will post up as we go.
great job Duke!
great job Duke!
Car: 2015 Chevy SS
Engine: LS3
Transmission: 6L80E
Nice man, those look great! I replaced mine this summer when I did my headliner, but I just ordered aftermarket ones because I didn't feel like stitching anything.
What did you end up using for the trim on your t-tops? I just wrapped my material over the bar and under the seals (the way C&C did it) but I see yours doesn't go all the way up?
Car: 04 Silverado
Engine: 4.8
Transmission: auto
I am installing an overhead console soon and am now trying to figure out a way to suck up the rest of the gap
It doesn't look too bad but my headliner was so thrashed I didn't even realize the material was wrapped in the first place. If I can't live with it I will go to the JY and get a hardtop board and redo it, but it looks ok.----------
great job Duke!
great job Duke!
Last edited by 82 Iron Duke; Dec 18, 2007 at 07:13 PM. Reason: Automerged Doublepost
I may be wrong cause I havent messed with a 3rd gen in a long time but a hardtop headliner will not owrk to cut out a ttop headliner.I think the parts aroud the t-tops curl up some.But if you end up doing that,take pics and explain it all to the massess..lol
Car: 04 Silverado
Engine: 4.8
Transmission: auto
I have C&C t-tops, they are an after market t-top. C&C converted hard top cars into t-top cars and all they did was cut the hartop headliner and reused it with a little work.
Car: 1987 Camaro SC, 1999 Z28
Engine: GMPP 350HO, LS1
looks great!
Car: 89 Camaro RS
Engine: 2.8 V6
Great post , just re-did mine after reading this used the poster board ,thought one peice was to light so cut out 3 and glued them together ,cost a whole $4.00 for the poster board , fabric , glue , and thread .They turned out like new Thanks...
Car: 04 Silverado
Engine: 4.8
Transmission: auto
Car: 81z-28,89gta,91z-28 03 1500
Engine: 355,L98vette tpi,327
Transmission: TH350/700R4/700r4/4l80E
Axle/Gears: 3;73/3;27/2;73/3;73
thats alot of work IMO for something thats not really needed.
82IRONDUKE,the visors do look good.
I just like the look of no visors at all.
Of course after replacing the headliner mat. and not cutting any holes where the visors are supposed to be.
Just makes a cleaner look to me.
Car: 04 Silverado
Engine: 4.8
Transmission: auto
It also helps keep the headliner up in t-top cars
Car: 04 Silverado
Engine: 4.8
Transmission: auto
HMMMMMMM, I was bored and I suppose I wanted to keep it as stock looking as possible.
Last edited by 82 Iron Duke; Dec 28, 2007 at 04:57 PM. Reason: Automerged Doublepost
Car: 1984 Trans Am 15th anniversary
Engine: L69
Transmission: 700r
Axle/Gears: 3:73
Car: 04 Silverado
Engine: 4.8
Transmission: auto
I just thought I would add this picture, I installed an overhead console this weekend. it was a PITA but I am happy.
[IMG]
[/IMG]
[IMG]
Car: 04 Silverado
Engine: 4.8
Transmission: auto
Just a quick hand sew.
It's fun, easy, and inexpensive and you get a good feeling when you sit in your baby. You can say I DID THAT
Last edited by 82 Iron Duke; Jan 16, 2008 at 07:09 PM. Reason: Automerged Doublepost
Car: 1991 RS, 84 El Camino conquista RIP
Engine: 5.0 (for now)
Transmission: 4L60
Axle/Gears: 2.xx torsen limited slip & 3.42 ope
can you give the link to the first thread. I want to do my passenger sail over again and need the material (grey). Thanks!! looks great!
Car: 04 Silverado
Engine: 4.8
Transmission: auto
Just pull the old material off and use the same headliner material and some contact cement
Car: 91 RS
Axle/Gears: 10 bolt
Nice! Ima have do add this to my to do list! I love it when I can do things myself instead of pay for a new one
Car: 04 Silverado
Engine: 4.8
Transmission: auto
Car: 04 Silverado
Engine: 4.8
Transmission: auto
Car: 04 Silverado
Engine: 4.8
Transmission: auto
Car: 1984 Camaro Z28
Engine: 357 SBC
Wondering if some one had a template that they can email me. Mine were so far gone to use as a template. I just bought all the stuff and need a template. The car is a 84 camaro non t top. Thanks guys
Car: 04 Silverado
Engine: 4.8
Transmission: auto
I would send you a template but my scanner is not that big. If I were you I would just use the visor board and leave an extra inch of cardboard all around. Use the pictures as reference and cut to fit.
Sorry to bump a older thread, but I just want to thank Iron Duke for this "How 2". I was a bit intimidated by interior work for no reason at all. But this made it a quick and cheap for me (38$ and some change) and it looks damn good, so thanks.
Car: 04 Silverado
Engine: 4.8
Transmission: auto
Car: Different Rides but 1991 Firebird
Engine: V6 3.1 in Bird
Nice job iron duke, Im right now trying to make a decsion on keeping my visor or deleted them. I figure I can run a 4 to 5" tint on the top of the windshield and that will be that, but not sure yet. I need to redo my ttop headliner also. Hope the board is still good enough for another recovering.
Car: 87 GTA
I was getting pissed at my old visors, especially the driver's side. It would not stay up for the life of me so I was constantly pushing it back up. I finally just removed them entirely. I was going to get a new headliner, and install it without visors. I am always wearing sunglasses so it shouldn't be too bad.
Car: 04 Silverado
Engine: 4.8
Transmission: auto
the bike rider was on the wrong side of the road, good thing she wasn't hurt. Supreme Member
Car: 89 IROC-Z
Engine: 370 LSX, LS3 Top End
Transmission: Built T-56
Axle/Gears: 9" Aluminum Center 3.89's
This is one of the BEST fabric restorations i have seen!!! Im gonna do this hopefully this week! Very nice work Iron Duke!!!
Car: 89 IROC-Z
First question is did you already have a mirror? If you did you already know that you could just cut slits in the fabric and pop the mirror back in place. If you didn't have a mirror you would first have to find out were the holes are supposed go, carefully drill out the wood (to the right size) and NOT poke through the other side of the fabric lol , pop the mirror into place, and walla! you should now have a mirror!! if you want i can get you the size and exact location of the holes if yours a t-top visor. just ask if you got any questions
