Shift Knob Trouble! Help!
Shift **** Trouble! Help!
Okay, the shift ****, of all things, has me stumped. I have an '86 IROC with an automatic transmission and the round shift ****. Since I bought the thing in '92, the shift **** has been held up with electrical tape wrapped around the shift rod. The retaining clip IS there and it IS keeping the **** from wanting to pull up and off of the shifter. So it's doing it's job...
But what I CANNOT figure out is what should be holding this **** UP and keep it from sliding down?? Is there something that's missing from my **** that keeps it from doing that? Am I not understanding or using this retaining ring correctly? Man, if anyone has any pics to go along with their explanation of what's going on, I'd really appreciate it. The **** just wants to slide down and sit on the console. I'm stumped. I don't see any way of searching the site for this information so I'm posting a new thread.
From: Somewhere around the South Side of Chicago just crusin' in one of the Niteriders
Car: 92RS 25th Anniv./88 IROC Z28 Vert
Engine: 305 TBI w/Tpi Air / 305 TPI
Transmission: 700r4/700r4
Axle/Gears: Posi
Re: Shift **** Trouble! Help!
If it is like mine the electrical tape is keeping it from sliding down to the shift plate and the retaing ring (inside the button) is keeping the **** from coming up off the shifter.
Axle/Gears: Posi
Car: 83 Trans Am / 96 Jeep XJ
Engine: 355 / 4.0 I6
Transmission: TH350 / Auto
Axle/Gears: 3.23 10-bolt / 4wd
idk, but i have the same one. it has a shell around a smaller ball, that breaks apart into 2 pieces. then i slid it down and the button came out, then you can take the ball off... not sure if that helps....
A C clip. use a flashlight and look real hard, its there trust me.
Under the button of course.
Maybe I'm not saying this right...I know where the c-clip is, or the "retainer ring" some call it. The button has been removed, the c-clip has been removed, and the ball has been removed.
The function of the c-clip seems to be to keep the shift ball from coming off of the shifter or from moving "up", if you will. So, I will ask again, what keeps the shift ball from moving DOWN?? What holds it in place that way? Am I asking this where people can understand it?
Car: 1982 Trans Am & 1982 Corvette
Engine: L-98 with LO-3 induction. 350 CFI
Transmission: 5 speed and vette has 700r4
Axle/Gears: 373's in T/A .. vette unknown
I kinda remember the shifter had slots in it and the **** slid into these slots. maybe that is whats missing on the inside of you ****.
Car: 92 RS(sold) 1989 IROC-Z
Axle/Gears: ones that turn
okay.. I think that the plastic is molded in a way that wont allow it to slide down. you can twist it a bit, and it will go a little further then stop, i am unsure exactly what it is, but i am thinking that its just the way its molded...
Car: basic third gens
Engine: that I like
Transmission: to restore
Axle/Gears: and enjoy
On the top of the shaft, there is a slot on one or two sides depending on the year. The inside of the **** is supposed to have a tab that sticks out and goes into that slot to locate the ****. It also keeps the **** from sliding down toward the shift plate. That tab is probably broken and/or gone.
Night rider327
Feb 25, 2016 09:50 AM
there should be a slit somewere on the front were the c clip slides in to hold it on on and prevent it from moving up and down
