Where to get new foot area dash panels??
Car: 1987 Chevrolet Camaro SC
Just a simple question about dash panels...
I do not know the name of it but the panel that is above your legs on drivers side. where you have the fuses and everything is broken with me...
So I have to replace it...Anyone knows a site that sells this???
I tried Hawk's but I didn't find anything there..
Re: Where to get new foot area dash panels??
Almost
...The part you mount this fuse box cover on
any idea???
https://www.thirdgen.org/forums/inte...have-left.html
i found this he is selling him pm him and ask if he has it still
Car: 88 IROC
Engine: 305 TPI w/ l98 cam
Transmission: T5 5-speed
Axle/Gears: 3.45 posi disc 9 bolt
is that panel you are talking about different between manual cars and automatic?
Car: 80 SE/TTA;88 T/A GTA;86 T/A
Engine: 4.9L Turbo; LT1; empty
Transmission: TH350; T56; empty
Axle/Gears: 3:23 disk; 4:10 disk ; 3.42 disk
shouldn't be, only diff should be if you have manual vents with a non-ac car or an a/c car
PM sent.
PM sent.
Car: 1992 Pontiac GTA
Engine: 305TPI
Axle/Gears: 10-bolt, 2.73
The panel where the fuse panel door mounts is called a sound insulator panel, or more commonly a driver's side hush panel.
I am sure that Bruce at Hawk's will have one that will fit your '87. I do not know if he'll ship to Norway or that you'll like the postage to do so either.
Modern day Muscle (formerly PeryPam.com) has the part listed,http://www.moderndaymuscle.com/inc/sdetail/1121.
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
The Firebird Hush Panels are not the same as a Camaro Hush Panels either. You might be able to "Make" it work - but they are different.
If you can't find anyone willing to ship to Norway let me know. I'll sell one for an 87 IROC automatic for $15 or a Pair of driver and Passenger hush panels for $25. Good shape with no cracks or damage. If you need a fuse panel or the the little diagnostic port trim panel they are avaiable at an additional cost. ( PayPal payment only please ! )
Shipping one of these to Norway will cost approx $30-$35. If you are serious about buying one than I'll box it up and get an exact shipping quote for you.
Car: 88 IROC
Yes,..... They are different from Manual to Auto. The manual has an additional notch cut from it to accomodate the clutch pedal. The Non-AC cars had yet another style hush panel for each of the auto and Manual cars too.
thank you! everyone i have talked to or heard from said they were the same i knew it couldnt be because my auto one wouldnt work... i need to find one for a manual BAD!!
throw an add up in the interior parts wanted section, bound to get some results! Good luck!
