is there such a thing as a 145mph factory set thats a cable driven speedo?? (firebird
Old Dec 2, 2007 | 07:59 PM
NORTHSLIDER's Avatar
Car: 79, 85, 87,91 TRANS AM'S
Engine: 455,305TPI,350TPI,350TPI
Transmission: MUNCIE, T-5, 700R4'S
Axle/Gears: YEP
is there such a thing as a 145mph factory set thats a cable driven speedo?? (firebird) if so im looking for it cause i cant get my electric one to work do to i sold the tpi setup (wiring and computer)
Old Dec 2, 2007 | 08:05 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: is there such a thing as a 145mph factory set thats a cable driven speedo?? (fire
im quite sure the answer is no
Old Dec 2, 2007 | 08:53 PM
white85transam's Avatar
Car: 85 trans am
Engine: 383 stroker
Transmission: 5 speed
Axle/Gears: 9 bolt rear 3:70
as far as i know the answer is no too but if you can find a cable driven speedo you can send it to fbodymotorsports and they can recalibrate it and reface it to 160mph. i hope that this helps.
Old Dec 2, 2007 | 09:10 PM
Titan85's Avatar
Car: 1987 Camaro SC
Engine: 305 LB9
Axle/Gears: 3:42
If I understand what you are asking correctly, the answer is yes: http://cgi.ebay.com/ebaymotors/85-89...QQcmdZViewItem
Old Dec 2, 2007 | 09:33 PM
ND4SPD86's Avatar
Car: 87 Buick Regal T
Axle/Gears: 2.56 blah
He was asking it there was one for the Firebird's not Camaros. He would have to have custom made like white85transam said.
Old Dec 2, 2007 | 09:37 PM
Titan85's Avatar
Car: 1987 Camaro SC
Engine: 305 LB9
Axle/Gears: 3:42
Ah, it would help if I can read.
Old Dec 3, 2007 | 07:05 PM
Axle/Gears: YEP
i was told by a co-worker i could get a computer and hook it back up if i know were all the wires i need go (grounds, power sending units needed) i sure i might be able to ground all the grounds powers and the vss sender and it might work your thoughts?
Old Dec 3, 2007 | 07:14 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
You don't need the computer for the speedo to work.
Old Dec 3, 2007 | 09:29 PM
Axle/Gears: YEP
then please explain how to get it to work ....please
Old Dec 4, 2007 | 06:43 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
you have the speed sensor in the trans, it has 2 wires, yellow and purple.
they go under the passenger dash into a yellow box that is/was attached to the side of the computer, from there a green/black striped wire goes to the speedo and there is a pink/black accessory power wire going into the box and a ground. With all that hooked up you are golden.
Old Dec 5, 2007 | 08:05 PM
Axle/Gears: YEP
okay i understand everything you just wrote. i did all that and it didnt work. i ordered from south carolina the last vss for a t5 tranny from, a dealership. coast my $60.00 cause i think the one i got is bad. i will try again when it gets here. thank you for explaining it to me buddy.
Old Dec 7, 2007 | 06:37 AM
92RS(real slow)'s Avatar
Car: 92 RS(sold) 1989 IROC-Z
Axle/Gears: ones that turn
didnt the some of the mecham TA's come with 140 and 160 speedos Im pretty sure they were cable
customblackbird
Aug 15, 2021 10:16 PM
Vintageracer
Jan 10, 2020 05:33 PM
colton_carlson
Mar 8, 2019 12:21 PM
Bob88GTA
Aug 18, 2015 03:31 PM
mx127
Aug 10, 2015 08:13 AM
