stumped how do you remove the shifter plate?
Old Dec 12, 2007 | 11:33 PM
FireBirdKnight's Avatar
Car: 1985 TransAm
Engine: 5.0L TPI
Transmission: 700R4 auto
Axle/Gears: 3.27 BorgWarner
my shifter plate has a crack in it i can only see 3 , 7 mm bolts holding it on , do i need to remove the radio and pod ? it wont budge by the front area the back will come out freely
Old Dec 12, 2007 | 11:41 PM
Demon355's Avatar
Re: stumped how do you remove the shifter plate?
There should be 1 or 2 bolts in the ashtray holding the front in.
Old Dec 12, 2007 | 11:45 PM
Car: 1985 TransAm
Engine: 5.0L TPI
took it out theres only 1 , its still fighting , what about the cig lighter?
Old Dec 12, 2007 | 11:49 PM
89RS_82Z's Avatar
Car: 89RS(other cars & pics in vBgarage)
Engine: LO3, 305 TBI Mildly Modified
Transmission: BakerBuilt 700R4 w/B&M Megashifter
Axle/Gears: 3.23 Auburn Pro Series LSD
camaros you got to remove/losen the radio/hvac trim or its vise versa i cant remember and i should i just did it a few days ago, both ways LOL, not sure about the birds hope, but i figured i would try to help
Old Dec 13, 2007 | 03:58 PM
Demon355's Avatar
Wiring might hinder it from coming out as well. I know on my old GTA that was the problem and had to remove the brace on one side to get it out. Not the biggest problem but a problem none the less. If all the screws are removed then look for wiring, the radio trim or pod for that matter, handbrake handle etc.
Old Dec 13, 2007 | 04:39 PM
84redta's Avatar
Car: 80 SE/TTA;88 T/A GTA;86 T/A
Engine: 4.9L Turbo; LT1; empty
Transmission: TH350; T56; empty
Axle/Gears: 3:23 disk; 4:10 disk ; 3.42 disk
Shot of underneath of an automatic shifter plate (85-92 i believe), there are only 3 pressure clips, 2 right behind the shifter, and 1 underneath the ashtray, and only 3 screws, 2 underneath center console lid and again 1 underneath the ashtray. After that it's just convincing the part that it wants to come out, only real wires that would prob give you a slightly hard time are the cig lighter ones, i don't think there is much for the shift indicator light to get caught on. Good luck!
Attached Thumbnails stumped how do you remove the shifter plate?-mounting-tabs-firebird-shifter   stumped how do you remove the shifter plate?-mounting-tabs-firebird-shifter
Old Dec 13, 2007 | 08:19 PM
Car: 1985 TransAm
Engine: 5.0L TPI
so im guessing i dont have to remove the radio pod? just have to use a lil effort to get it to pop?
Old Dec 13, 2007 | 08:30 PM
92Z28/RS's Avatar
Car: 92 Z28 and 92 RS
Engine: 383
Axle/Gears: 4.10
You have to remove three (maybe two) bolts from the console, remove the staple from the back side of the shifter ****; remove the three bolts holding the trim on around the AC/Radio, and the three or four bolts around the ashtray/shifter. The trim around the AC/Radio and be tricky. Tilt is up at a 33 degree angle and pull towards the passenger side.
Good luck
Old Jun 22, 2008 | 06:43 PM
V8Rumble's Avatar
Car: '89 Trans Am GTA
Engine: WAS 350 - now L92 (alum. 378/6.2L)
Transmission: WAS 700R4, now a built T56
Axle/Gears: 3.27 9-bolt
Man, if this isn't in a sticky somewhere, it SURE AS HELL oughta be! Geez, I've gotten the shifter handle & the two bolts off, I've been gently twisting, tweaking, pulling, looking, & I still couldn't figure out how to get that sucker off...
This is where it kinda sucks to have a car that's in good shape, because if it was crappy I could've just hit it with a prybar & I would've been further ahead with my swap by now...
Old Jun 22, 2008 | 10:11 PM
mmm88TA's Avatar
Engine: 5.0 TPI
Transmission: TH700R4
Axle/Gears: 3.43 posi
there's 3 bolts holding it in 2 by the armrest 1 under the ashtray take the radio trim off and you should be able to wiggle it loose, there's wires connecting hooked up to the lighter and the switches but you should have enough slack to get it up and disconnect them
Old Jun 24, 2008 | 12:22 AM
V8Rumble's Avatar
Yeah, the problem that I'd been having was that it didn't want to wiggle at all, it seemed as though it was bolted in, & I couldn't FOR THE LIFE OF ME see where it could be bolted...
Thanks for the info though, it's dead-on accurate.
BewleyBizzIROC
Feb 3, 2020 09:52 AM
BumpaD82
Members Firebirds
31
Apr 4, 2019 10:36 AM
rh76camaro
Exterior Parts for Sale
Aug 29, 2015 06:55 AM
NBrehm
Aug 25, 2015 11:49 PM
3rdgenparts
Aug 8, 2015 07:09 PM
