odometer broke
Old Dec 16, 2007 | 06:54 AM
LoganTA's Avatar
Car: 87 Silver Formula
odometer broke
On the 88 Formula we just bought,the odometer and trip odometer is not working.Everything else is just fine.
Would the problem be inside the unit? Can it be fixed or easier to swap out a working one?
vince
Old Dec 16, 2007 | 01:54 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: odometer broke
you can take it all appart and see if there are any broken wires, but there is a little motor in there and it can go bad, you will have to dig into it and see, maybe its just unplugged, who knows
Old Dec 16, 2007 | 04:53 PM
Titan85's Avatar
Car: 1987 Camaro SC
Engine: 305 LB9
Axle/Gears: 3:42
Re: odometer broke
A common problem with the thirdgen speedos is that the j-clips that hold in the trip meter and odometer (although I have not heard of the odometer clips breaking) have a tendency to break. I would check on those while you are looking at the speedo.
If your speedometer still works, then the problem should not be that it is simply unplugged so the issue would be with the motor or clips.
Old Dec 17, 2007 | 09:46 AM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Re: odometer broke
IMO the first thing you should do is to see if the speedo sending unit in the tranny is plugged in !!
If it is plugged in that you will need to work your way back into the car...... Start by removing the speedo sending unit in the tranny to be sure the driven gear is OK on the sensor and that the Drive gear on the tranny tail shaft is still in place. If it's fine just re-install the sending unit. Then check the sensor wires to be sure they are not broken. If all that check out than deal with removing and checking the cluster.
Old Dec 17, 2007 | 09:49 AM
LoganTA's Avatar
Re: odometer broke
wouldn't be the case if the speedo didn't work..mine does
the odometer isn't working
Pac J
May 17, 2020 10:44 AM
Bubbajones_ya
Oct 25, 2015 08:01 PM
wanext
Oct 6, 2015 12:18 AM
bjpotter
Oct 4, 2015 07:48 PM
sjorgens
Oct 1, 2015 07:54 PM
