Door Won't Shut
Old Dec 21, 2007 | 09:49 AM
Avizion's Avatar
Door Won't Shut
I've searched the past threads for this article and it seems no one has had this problem posted yet. This morning I went out to my car and opened the passenger side door. I went to close it and it just bounced right back open. The latch in the door isn't catching and I was wondering what I would need to do to fix this. Is there a cable inside that may have come off, has a spring broke, will I need to replace it? Thanks in advance for any help.
Old Dec 21, 2007 | 11:31 AM
TA In Progress's Avatar
Axle/Gears: 3.27 BW
Re: Door Won't Shut
I've had a few vehicles do this when it was really cold outside (don't know what part of country you are in) and there was some moisture in the latch that had frozen and wouldn't allow the catch to move properly. Try some lube in the latch, like WD40, and move the catch with your hand. That usually worked, but once I had to put the car in the garage with heat until it thawed. Once it was thawed, I lubed it a bit and no more issues.
Old Dec 21, 2007 | 01:52 PM
Avizion's Avatar
Re: Door Won't Shut
I'm in Utah and we just had a really bad snow storm and you're right. It froze up because I went back outside a little later to mess around with it and the latch caught on. Thanks again.
Old Dec 23, 2007 | 11:39 PM
Axle/Gears: 3.27 BW
Re: Door Won't Shut
Glad to help. That's definitely a frustrating problem.
Matt86IROC
Sep 7, 2015 06:30 PM
Out-Cast
Aug 23, 2015 06:33 AM
BlackTopKing
Aug 19, 2015 12:13 PM
Fronzizzle
Aug 9, 2015 01:15 PM
BrianI
Aug 9, 2015 11:52 AM
