Loose Steering Wheel?
Old Dec 31, 2007 | 11:31 PM
slow_90firebird's Avatar
Car: 90 Firebird Formula
Engine: LO3
Axle/Gears: 3.08 one wheel peel
Alright, I have read alot of threads about the "loose tilt wheel." I think i have this problem. However, it doesent really make sense.
What happens is, if the steering wheel were a clock, i would push on the 7:30 position and it would move about 1/2 inch. So normally it is straight, but if I push it can go to the bottom left area.
However, if I use the tilt control, the wheel goes straight up and down! So something else must be loose. I have never had any steering wheel off before, and have no idea how they work. So the steps to tighten "loose tilt wheel" dont make any sense to me.
Anyway, if this is the same problem we are talking about, how much would the dealership charge to fix it?
Thanks for the help!
Old Jan 1, 2008 | 12:07 PM
86blackiroc's Avatar
Car: basic third gens
Engine: that I like
Transmission: to restore
Axle/Gears: and enjoy
Re: Loose Steering Wheel?
You just described the common symptoms. As far as what the dealer would charge, it depends on what the labor rate is and if they are willing to mess with your car. They may just run you off or quote you a very high price.
Old Jan 1, 2008 | 12:30 PM
92 CaMaRo Rs's Avatar
My camaro has the same problem but ive takin the steering wheel off 2 times and put it back together tighting it down good still does it so i said screw it.
Maybe a answer here could help me as well.
Old Jan 1, 2008 | 01:14 PM
Engine: that I like
It's a lot more involved than just taking the steering wheel off and putting it back on.
Old Jan 1, 2008 | 01:19 PM
83Chevy__Camaro's Avatar
I used the articles i found on google to tighten mine, its solid now, i reccomend searching on google and using the ones you find there. I also replaced the turn signal switch, and the steering wheel nut with a new GM and put a washer behind it to tighten it up even more, brand new now.
morrow
Jan 13, 2024 12:29 PM
83 Crossfire TA
Jan 3, 2016 01:26 PM
wild1
Aug 27, 2015 09:01 AM
Keiffer76
Car Audio
Aug 9, 2015 11:37 PM
mustangman65_79
Aug 9, 2015 03:00 AM
