Need tips on firebird custom gauge panel
Old Jan 2, 2008 | 10:51 PM
Jakout125's Avatar
Im hoping to get tips on how to make a custom dash for a firebird, any pics and how to go about it would be helpful. I've seen camaro ones all over tryin to do the same with my bird!!!
Old Jan 3, 2008 | 09:25 AM
Karps TA's Avatar
Car: 1985 Trans Am
Axle/Gears: 3.70
Re: Need tips on firebird custom gauge panel
You'll need to basically get rid of the cluster and use the outside trim piece as the mounting place for the brackets.Then it all depends on what you want to accomplish. I cutoff the beveled gauge holes, then filled in the holes with ABS plastic. Used plastic filler to give myself a blank slate and then cut my new gauge holes. You'll need to then put together a wiring harness and spice into the original harness, or run new wires to the sending units.
It's a bunch of work, not as plug and play as the Camaro can be. But it's not too difficult.
Here's 1 pic. I've got others at home that I can post if need be.
Old Jan 5, 2008 | 01:28 PM
Jakout125's Avatar
Hey that looks sweet thats exactly what I'm looking to do on mine, would you have a pic of the back of the cluster, also did you cut out the factory guage rings completely?
Old Jan 5, 2008 | 03:02 PM
Karps TA's Avatar
Car: 1985 Trans Am
Axle/Gears: 3.70
Sorry looks like I don't have any pics of the back side. Could of sworn I did. I did use Painless Wiring, gauge harness, which IMO made things a little neater and simplier. I forgot to mention that.
Yes I cut the rings down completely. If you use a 5" gauge like I did for the speedo and tach that the stock holes are just a little too small.
And to connect the other 2 holes for the smaller gauges you'll need to take those rings off as well. I got some abs plastic from www.mcmastercarr.com I don't remember the thicknesses but I measured the stock plastic, and got that size, then some thicker stuff for behind it to add strength to the panel. This is a little hard to explain, wish I would have took pics, but I always forget. If you want I'll try drawing something up to show you better what I mean if it's not making sense.
Old Jan 5, 2008 | 10:09 PM
Jakout125's Avatar
Trying to get a general idea. Where the red color is, is this the area that you cut out and then mounted the new plastic. Thanks for your help!!!!
Old Jan 6, 2008 | 11:01 AM
Karps TA's Avatar
Car: 1985 Trans Am
Axle/Gears: 3.70
what's your email addy? I'll email you a word file with some drawings.
Old Jan 6, 2008 | 02:03 PM
Jakout125's Avatar
dynoraptor660@netzero.com
Ghettobird52
Jul 5, 2024 11:18 PM
Frozer!!!
Jan 19, 2024 04:55 PM
Jeremys87
Jul 14, 2022 09:08 PM
Dialed_In
Aug 20, 2015 01:45 PM
