broken tilt steering column
Old Jan 3, 2008 | 04:51 PM
92rs25thproject's Avatar
Car: 92 rs 25th anniversay edition
Axle/Gears: 3:49 stock
When I got my 92 the tilt wheel was broken and you have to push the wheel down and to the left for the tumblers to engage and for the VATS to kick in then move it up slightly to the upper left for the starter to engage then let go so it disengages. Likewise all I have to do to shut it off is yank down and left on the wheel and it kills the ignition. I plan on going to pull-a-part to get a close matching column then bypass the VATS system ( with resistors ) but I want a wheel w/o an airbag and mine came equipped with one.
Old Jan 4, 2008 | 09:16 PM
Re: broken tilt steering column
OK so I went to Pull a part today and got a titl wheel from a 94 camaro. All the 80's models were missing the columns and this one fits, but the shaft on the column looks to be a little long and it doesnt really wanna fit into the steering knuckle on the car. I wqas thinking about tolerancing it with an angle grinder but this column doesnt have the orange wire for bypassing the VATS system like the 92 column did... Any ideas? Basically im trying to see if its possible to put a 4th gen wheel on a 3rd gen car
Old Jan 5, 2008 | 05:47 PM
OK I switched out the 92 tilt column with the 94 column, replaced the ignition columns and it turns out I dont even have to bypass the VATS system, Got it all done except for hooking up the neutral safety switch, and reattaching the vats wires, that and my steering wheel is 90 degrees off so I have to unbolt it again and adjust the wheel other than that the 4th gen steering column adapts well in a 3rd gen
wigmobile
Feb 26, 2025 02:56 PM
RABMAN
Interior Parts Wanted
Sep 18, 2015 09:02 PM
Tweeks25
Sep 17, 2015 08:04 AM
SG91camaro
Sep 5, 2015 10:27 PM
Ian Irvine
Sep 4, 2015 08:08 AM
