help with HVAC
Old Jan 9, 2008 | 11:20 PM
topless89's Avatar
Car: 89 RS Convertible
Engine: 305 tbi
Transmission: 700R4,B&M friction,Transgo shiftkit
Axle/Gears: 2.73 LSD
help with HVAC
i've got an odd problem with my HVAC. if i have the switch set to ac, bi-lev, vent, heater, or defrost the air only blows through the defrost vent under the windshield. the only way to get air to come through the other vents is to set it to max ac. sometimes if i run it on max ac for 5 minutes then change to vent or heat it will continue to come from the vents. anyone know what's goin on?
Old Jan 10, 2008 | 12:20 AM
MPNolin's Avatar
Car: 1985 Camaro Sport coupe
Engine: GM Crate 350
Axle/Gears: Stock, 3.23
Re: help with HVAC
Check the vacuum diaphram just above and to the right of the gas pedel under the dash. You will see a vacuum line with a clear elbow plugged into it. This changes your air door setting. Is the vacuum line still plugged in?
Its posible to kick it loose. If not, Can you hear a hissing noise from under the dash with the engine running? (vacuum leak)
Old Jan 10, 2008 | 12:55 AM
84redta's Avatar
Car: 80 SE/TTA;88 T/A GTA;86 T/A
Engine: 4.9L Turbo; LT1; empty
Transmission: TH350; T56; empty
Axle/Gears: 3:23 disk; 4:10 disk ; 3.42 disk
Re: help with HVAC
second that! It's a vac leak that causes it to get stuck on defrost. Had that in my '88 RS, was a pain to find the leak, had to tear the entire dash out to find the nice little mouse nest. HVAC hoses all intertwined and chewed within the nest, lol. Good luck!
Old Jan 10, 2008 | 05:31 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: help with HVAC
Stick an ear to the HAVC head. Should you hear a hiss, your problem probaby stems from the vac control valve:
https://www.thirdgen.org/forums/atta...duct010707.jpg
https://www.thirdgen.org/forums/inte...ctor-disc.html
By the way, this problem is common to thirdgens, so a search will provide pages of info.
JamesC
Old Jan 10, 2008 | 10:23 PM
topless89's Avatar
Engine: 305 tbi
Re: help with HVAC
thanks for the info guys
Casey Meyers
Mar 2, 2016 10:46 AM
777Shock777
Oct 29, 2015 04:30 PM
timonator
Sep 30, 2015 12:52 PM
Chevykid810
Sep 28, 2015 12:57 PM
Eric-86sc
Sep 28, 2015 11:37 AM
