Speedo Swap?
Old Jun 17, 2011 | 06:25 AM
  #51
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Speedo Swap?
Originally Posted by evilemokid94
how do you lube the cable?
Check post #1 below:
https://www.thirdgen.org/forums/inte...eedo-woes.html
And while the cluster is out, and if your trip odometer doesn't work, check the following info:
https://www.thirdgen.org/forums/faq-...-fix-pics.html
JamesC
Old Jun 17, 2011 | 08:44 PM
  #52
titan7's Avatar
Car: 1985 camaro
Axle/Gears: 3:42
Re: Speedo Swap?
I have a 1985 camaro with a 3:42 posi ,i've swapped a 96 lt-1 / 4l60e ..need some guidance on hooking up the guages and speedo any idea's?
Old Jul 31, 2012 | 11:00 PM
  #53
jpearcy1's Avatar
Car: '87 Iroc
Engine: 350 TPI with Holley Terminator X
Transmission: 4L60e
Axle/Gears: Stock/ Factory
Re: Speedo Swap?
hey hate to bring back an old thread but does it matter if the clusters are from a V8 to a V6?? I did a search and found this thread. Thanks
Old Aug 4, 2012 | 07:10 AM
  #54
Hillbill6461's Avatar
Re: Speedo Swap?
i have a question are u able to run mechanical gauges with tpi system? or will it screw up computer
Jorlain
Aug 24, 2022 05:11 PM
Eric2ndGen
Nov 5, 2015 01:51 PM
stickychinsac
Aug 31, 2015 06:06 AM
IROCZDAVE (88-L98)
Aug 24, 2015 06:54 AM
beachrodder
Aug 7, 2015 04:27 PM
